Old 02-20-2025, 01:41 PM   #1
beowulf556
Drives: Camaro SS 1LE M6
Headers and wire harness protection
Just put on headers, wrapped the wire harness with DEI heat shroud. Is this good enough protection/clearance from the headers?
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 02-20-2025, 04:51 PM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Good job... I did the same thing
Old 02-20-2025, 05:16 PM   #3
beowulf556
Thanks for the reassurance! Does the velrco on the heat shroud hold up pretty well?
Old 02-21-2025, 07:24 AM   #4
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
I would move the entire harness as I did, between the coolant bottle and strut tower. If you do a little digging, you will see that there is plenty of length to make it happen. Get some of the larger zip-ties from Harbor Freight and use them to secure the harness to the battery cable which already makes this path.
What I would be concerned with and I brought this up in a FB thread before... is the front right brake line that is extremely close to the header tube. I removed my line and using a bending tool I bought at O'reilly's, straightened out the first two bends and relocated it to exit the frame ahead of the subframe mount instead of behind it. I then used the DEI sleeve to cover the brake line to offer more resistance to heat.
I have run a dozen trackdays since this change on my ZLE with zero heat related issues to the wiring or my brake line.
My apologies for not having photos of this at the time, as I purged my iPhone to make more space for current upgrades. Hope this helps.
Patriot Motorsports USA is offline   Reply With Quote
Old 02-21-2025, 07:38 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That should be good to go.
Old 02-21-2025, 07:53 AM   #6
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Use one of those zip ties that has a push lock fastener on it. Then use the existing hole in the frame right there to push the fastener into and then zip tie the harness down. Re-install the coolant reservoir with the harness running along in the inside between the frame and reservoir.
The Velcro holds up fine as long as there isn't direct contact.
GM Gen V Calibrator
Old 02-22-2025, 05:01 PM   #7
beowulf556
Do you have a pic? I’m having a hard time visualizing what you’re saying. TIA.
Old 02-22-2025, 05:19 PM   #8
He means cable ties with a [Christmas] tree mount like the one in this pic. You can push the clip section into a hole in the frame, then you can use the zip tie section as usual, it will be held in place by this solid mount and won't move around or loosen.
Old 02-22-2025, 05:53 PM   #9
beowulf556
Which hole in the frame? I don't see anything behind the coolant tank? Do I need to make one?
Also my pictures don't show it, but the harness is still zip-tied with the factory ties. I cut a slit in the heat shroud to slide around them.
Old 02-23-2025, 07:37 AM   #10
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Yep those are the zip ties I was talking about. The square hole is right there. Go look by the harness. You can't miss it. Orient the tree stye zip tie in the direction that pulls the harness the furthest away from the headers. We do every install this way.
GM Gen V Calibrator
Old 04-20-2025, 06:21 PM   #11
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
How did this header install turnout any issues with heat? Did you coat these headers?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 04-21-2025, 07:50 AM   #12
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Interested in an update as well. Doing FBO+E soon on my wifes car.
CamaroDreams76 is offline   Reply With Quote
Old 04-21-2025, 09:39 AM   #13
SWFLZL1
Drives: 2022 ZL1
I wrapped my wire harness the same way, and also added some heat tape around the little brake line on the passenger side. I have 2” jet hot coated headers, and haven’t had any heat related issues yet.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 04-21-2025, 10:02 AM   #14
Dynamical
Dynamical's Avatar
Isn't that the same wire harness everyone talks about moving to the opposite side of the coolant tank? Doesn't look like it's on the opposite side to me in the pic, am I wrong?
I have been told by 2 good shops that coating headers on a street car is overkill, it's only needed if you're racing on a track and we're not talking about 1/4 mile drag. This is of course if the wire harness it moved. I realize this forum is bias for coated headers so I know I'm about to get hammered on LOL
