Old 02-11-2025, 04:01 AM   #1
towerfab
Drives: 2019 camaro ss
525 inline lowside experience
I curently have a dsx auxillary pump setup with a lt4 in tank pump. I'm in the process of installing dsx port injection and want to uprgrade the lowside but dont want to pull the aux pump set up. I will be adding a jms bap to help the lt4 pump and someone here suggested I replace the stock dsx aux pump with a 525. Are there any cons to this set up any suggestions on the preferred brand of 525 pump? The goal is getting to 4 digits rwhp. Thanks in advance, T.
towerfab is offline   Reply With Quote
Old 02-11-2025, 05:01 AM   #2
ZL14ever
Drives: 2018 Camaro ZL1 A10
525 pump has much higher current consumption, 18+ amps compared to 10-11 amps from DSX pump. It may not work with their controller & you would need another way to activate it
ZL14ever is offline   Reply With Quote
