Old 02-10-2025, 08:10 PM   #1
ALC
Drives: 2016 Camaro SS M6
Just got quoted $2600 by dealer for oil pan gasket
Surely this is not a reasonable price? Should I try other shops since they won’t cover it under my warranty?
ALC is offline   Reply With Quote
Old 02-10-2025, 10:35 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
WOW! Hope that includes lube, a reach around and a REALLY nice dinner!
Old 02-11-2025, 05:06 AM   #3
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Absolutely go somewhere else and get another quote!
dmcmahan60 is offline   Reply With Quote
Old 02-11-2025, 09:50 AM   #4
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
Just tighten the bolts and your leak will go away. 99% of the time it’s just loose oil pan bolts. Look it up, it’s a common issue on early LT1’s. The dealer told you that you need a new gasket because that will make them more money.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 02-11-2025, 10:08 AM   #5
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
My warranty was about to expire and took it to the dealer for a once over and they said there was evidence of oil on the pan but not dripping. They offered to replace the gasket under warranty. They had my car for a week and a half. What I thought was a standard drop the pan and replace the gasket is not the case. If you google it, they have to loosen the motor mounts, raise the engine, remove the starter, etc. Not knowing all this I inquired, they said there were back ordered one time use parts, plus to do this job there are 26 parts involved. There's a lot going on. I'm not surprised they are charging so much, but I'm sure another shop will bill less.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 02-12-2025, 11:29 AM   #6
ctrlz
So this is a 2016, which you have likely been driving for a while with no leaks. After 8 years it leaks, and dealer concludes the gasket did what?-- Disintegrated? Evaporated?
Bolts coming loose is far more likely than gasket trouble here. If a gasket is installed wrong, gets pinched or twisted-- typically that shows up pretty quickly.
Old 02-13-2025, 08:46 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I could see that if they are changing the oil pump as well.
Here is the thing though...these engines do not have gaskets. Both the timing cover and oil pan are installed with a sealant only. You likely just need to get up under the car and tighten the pan bolts. They are notorious for coming loose along with the 2 oil cooler bolts.
Old 02-13-2025, 04:30 PM   #8
cdrptrks
cdrptrks's Avatar
Agreed, happened to me two different times and tightening the offending bolt fixed the issue both times without removing the oil pan.
Old 02-15-2025, 02:01 AM   #9
ALC
Thanks everyone, gonna try and make time sometime soon to tighten those bolts and see what happens.
Old 10-09-2025, 04:26 PM   #10
cginn
Drives: 2017 camaro 1LT
I just got quoted today $3800 for my 2017 1lt! smh
cginn is offline   Reply With Quote
