Old 02-07-2025, 02:48 PM   #1
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Alignment necessary?
I got my new rims and tires on finally... Yay! Pics coming soon. Since I'm going from the stock LT1 set up to the wider 1LE type set up, will an alignment be necessary? I figure yes, but thought I'd check before spending the money.
Prev: 20x8.5 with 245/40R20's all the way around
New:
Front - 20x10 +25 with 285/35R20
Rear - 20x11 +35 with 305/35R20
I wasn't sure if this question should go into the Wheel section or Suspension.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 02-07-2025, 03:07 PM   #2
atx_traveler
Drives: blue velvet
nah you should be fine. alignment doesn't change from changing wheels
atx_traveler is offline   Reply With Quote
Old 02-07-2025, 03:25 PM   #3
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
When was the last time you had an alignment?
If it has been a few years maybe it would be a good idea. That is what I would do.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 02-07-2025, 07:41 PM   #4
Technically, no alignment is necessary after changing just wheels and tires.
Since these 1LE sized tires are chonkier, they tramline more easily (depends on brand and product, too), so the previous alignment that was good enough for the skinny tires may need to be tightened up a bit for the new steamrollers to feel just as solid.
All in all, I'd get an alignment just to make sure it's 100% on the money.
My car has similarly sized tires, and after the last alignment done by a true artiste I can now let go of the wheel, give it gas or brake or just coast, the car will keep going straight on its own for at least a quarter mile if not more, depending on road crown and quality. That's the target to shoot for
Old 02-10-2025, 11:09 AM   #5
bandier
Got mine!
bandier's Avatar
Thanks for the suggestions. I've driven with the new set up 2 days now and actually things feel really true. I was more concerned about the tires wearing funny on the sides or something, but if the 'chonkier' tires (I like that description. LOL) don't require any alignment adjustments. I may save the dough.
Old 03-17-2025, 07:28 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I would get it checked. The check is usually free and they only charge if it's out. You absolutely want to know that the toe is set. The two Camaro's when checked have both been out of spec w/Toe when they were "new".
Old 03-17-2025, 12:11 PM   #7
bandier
Got mine!
bandier's Avatar
I ended up getting it done. Thanks. The alignment shop suggested a camber kit as one setting out of spec and was maxed out. I told them to hold off on the camber kit and do the best they can. Miraculously, when they finished the alignment settings, it pulled the maxed out setting back into spec. It's a good shop that specializes in alignment and hot rods; I am glad I didn't pay for the camber kit but question if they were trying to get a couple hundred bucks more out of me. Forgive my lack of proper alignment jargon.
Old 03-17-2025, 01:24 PM   #8
cdb95z28
cdb95z28's Avatar
Go somewhere else. Front or rear camber? For the love of God, those guys have no clue what they are doing or they are massive shysters. There's zero need for a "camber" kit on these cars. If they touched the rear camber and toe eccentric bolts they should have been replaced per GM. They are torque to yield bolts (TTY) and GM has a specific tightening procedure.
"KEEP THE FAITH"-Fbodfather
Old 03-17-2025, 06:05 PM   #9
DeuceCam
Drives: LT1
When they say 'camber kit', maybe they're referring to camber bolts?
DeuceCam is offline   Reply With Quote
