![]() Drives: Chevrolet Camaro zl1 Join Date: Dec 2023
Fender expansion tank
Hi,
What brand fender expansion tank is the best to use? Thanks. Anthony. |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Hey Chev, I have had and tested (2) so far. I would give the easy WIN to the DMS tank due to better fitment, and filler cap. They are the only fender tank I sell, and run it on my car currently. Here is a link... The tank is at the bottom of the list...
https://www.griffin-motorsports.com/shop
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
DMS - I only had to try one to know it was the best for fitment and function. Filling the tank and "bleeding" it (bleeding really isn't needed once you install a fender tank), is as easy as it gets ! The install is easy to. Listen to SOCAL.. Gabe, he will recommend the right stuff !
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Thanks, I’ll get the dms when I’m ready.
