Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
The finished work on my F.I. Interchiller
I never posted pics of what I did on this install, and I got a moment so here we go.
I made sure everything I could keep of the ZL1 stayed on the car, and I added something extra. As you can see, I kept the passenger side (for 375 of us RHD guys) air tunnels. I "dremeled" a hole just the right size to allow the hoses to pass through. I also cut the crash bar supporting plastic behind (and) the black foam into Threes. Therefore, the front facia is held on in the same way as stock. Yes, there was a lot of cutting (inch by inch by inch (actually more like mm by mm) to make it exact size) and dremel work on the plastic, especially around the Drier. The plastic actually surrounds the drier. Everything on the front stays tight on the car so driving over here doesn't shake anything loose, loctite everywhere. The air horn was connected using the intercooler bracket. I put the pics of that uninstalled here earlier. After a few thousand miles and being up over 120MPH a few times, everything is still tight in every way. I used wooden chair/table castor holders in multiple places, especially on the back of the foam to lock pieces down for stabilization. I find the utility of castor holders amazing. You can see two of them (upside down) holding down the front plastic cover. I'm contemplating putting some black screen (1/2" square holes) behind the front grill in an attempt to protect the interchiller hoses from debris. Because here you never know.... And I don't want to unnecessarily drive 40MPH at 2am barely touching the fuel because I have very hot MATs just to limp home.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Petro-sexual
Did you, also, remove the auxilliary blower HE, too? I think I remember CSP doing something similar when he was doing that on TREEL1...
![]() ![]() ![]() ![]() Drives: 2023 ZL1 - Beast Build Join Date: Dec 2022
Looks good! radz28 asked above and I'm curious too. Did you remove the stock HC? I bought the Stage 2 a while ago and Katech just installed it. Here are the pics they sent.
https://www.camaro6.com/forums/showp...&postcount=422 I had them remove the stock heat exchanger as after many conversations with Kirk @ FI Interchiller he told me the stock heat changer for my application isn't required. I drive my car only in good weather, spring summer good fall days etc. IT gets really hot in the summer here in Columbus OHIO so I will put mine to good use ! But regardless, I like seeing how others install the same products etc.
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#4 | |
Anyways, Yes, I also talked to Kirk extensively, and I initially was going to leave the heat exchangers it in for Road Racing. Andy at CSP called it a fail-safe in his video, and I talked to him once as well. However, after running Miss America for a few thousand miles while touring, no fail safe is needed if you're monitoring your temps with an i-dash. I drive my baby sometimes for 8 hours straight and it's great. Does heat soak take place? Yea, somewhat, after a while, but as long as your fan is set to most aggressive which Kirk recommends, and/or you have some wind on the condenser, the MAT temps drop right back to 80 (or probably less for you). And actually, my fans have yet to be tuned to most aggressive. I also don't have a tank yet. The chiller is awesome by itself. And I loved installing it. As for the heat exchanger(s). There are two of them, 1 in front of the A/C condenser and the other is where I put my Air horn, which will be fully operational for my next 2000km trip just before Valentine's day. The air horn is using the heat exchanger's bracket. That's what I liked about doing it myself. I could contemplate exactly what I wanted and how I wanted to accomplish it. I also cut out the solenoid and switch against the recommendation of Kirk. But this is Thailand. Unless you live in the North West (mountains), nobody ever drives without their A/C on, ever. In April it will be over 100 here. By the way, yours looks nice. Nice idea using the heat exchanger screen in front of the wheel-well vent. With my bumper off right now I might do that as well, Thank you
Yeah, I was going the fail-safe route just like CSP's video, but Kirk talked me out of it. So I just went as basic install as possible! All winter long I never wear a coat or even a jacket. Some people are just wired that way ! Take care and stay cool !
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
Maybe a little off topic, but how does it effect the inside cabin ac? I've read that it doesn't effect it much, but would like someone with actual experience to chime in. I only ask, because it gets super hot, 125 at times and I don't want to lessen my ac too much.
#7 | |
#8 | |
![]() Drives: 2017 ctsv Join Date: Jan 2024
fought with freon charge in mine for a little bit, but seems to be working well now (will know for sure as we get back into summer) cabin ac is a little diminished the first few minutes of driving while the hx coolant is getting chilled (chiller tx wide open) as the fluid is chilled, tx starts to close down and send more back to the cabin. if you overcharge it, it doesnt work as well in mine(ctsv) and i think your camaros have the same variable ac compressor, if the cabin temp is met it will start to lower compressor output, which lowers refrigerant to chiller also, itll keep fluid under ambient, but if you want it cold you need to leave cabin on max or have solenoid to blockoff cabin.
2017 CTS-V
10L90/NGD swapped, ARH 2"/Xpipe, BigGulp, DSX ti295s/fpcm, DSX LT4 Lid, DSX PI plates/Atlas Controller, Xport 2.30 Upper/ATI/9.06 Lower, CWA150 pump/12an hoses/InterChiller/LMP bumper tank, HPtuners/SBT 2012 Yukon Denali tms/fed 427, atfspeed 4l80/circle d, np149, gtx5533r/tial housing, aeromotive/fic, shearerfab hi ram intercooler, chiller/10gal res/cwa400, qa1, dub22/nitto, 2020 Silverado H/C 3.0L duramax/10sp/4x4, 43gal titan tank, PPE trans cooler |
#9 |
Interesting, thanks for the input! I'm torn between this and heat exchangers upgrade. I'll keep on researching, appreciate it!
#10 |
When I get my car back from Katech, I'll get some data and do some data logs and see what / how the FI Interchiller Stage 2 they installed helps, especially as it relates to the ECM pulling timing or not etc.
#11 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#12 | |
![]() Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
It definitely works, but until someone can figure out how to put a Prius or Volt AC compressor so it runs off the battery and doesn't shutdown when continuously WOT, it won't fully keep you cold for 30m. Regardless you'll be better off than the guy without one and the bypass valve can open and you'll be with your heat exchanger if you have one - once the IC fluid temp = ambient temps. |
