![]() Drives: 2016 Chevrolet Camaro 2SS Join Date: Feb 2024
lt4 injectors lt1 pump
Probably asked before but i cant find anything. Is it feasable or actually capable to run lt4 injectors on a lt1 pump with the aftermarket cams with 30% + fuel lobes? I do plan on doing the low side lt4 pump.
Need both the pump and injectors so you can run the correct rail pressure to fully utilize the injectors.
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
It's like $760 for a LT4 HPFP, $200 for LT4 High-side Fuel Lines, and I think it's like $15 for the .060" lash cap. What's the extra $800 for?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
![]() ![]() ![]() ![]() Drives: 2022 SS 1LE Join Date: Nov 2008
![]() Drives: 22 LT1 Join Date: Apr 2022
Rock auto had them cheeeeeaaaaap a while back. Dont know about now
#7 | |
OP price statement must be the full boat including injectors. Though everything from rock auto and Michigan Motorsports would be $~1560 or so.
#8 |
I noticed on ebay, there are now part numbered kits for upgrading an LT1 with the LT4 high side stuff. Pump, injectors and fuel lines. $2k
#9 |
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
Question. I’m high jacking I apologize. I know the 2018 SS pump is the LT4 pump. Is it also the injectors? Or would injectors and rails need to be upgraded still for a 2018 to add boost
#10 |
No it's not. 2018 SS has all LT1 fueling.
#11 |
Patriot
1 from. 2018 Ss. 1 from a 2019 SS.
#12 |
King is correct, the 2018 SS came from the factory with LT1 fueling (injectors, HPFP, LPFP). Some later model years of the SS received the LT4 low side fuel pump, but the high side remained LT1 all the way to the end. I would upgrade all three if I wanted to add boost (in fact I did, thanks to Jannetty Racing).
That said, part numbers evolve over time even when the content remains the same (say, when GM changes suppliers), and the above info only applies to stock, someone may have upgraded the high side on the powertrain you purchased.
#13 |
Patriot
Awesome sooo regardless of how it got there that does appear to be the LT4 pump (the one that’s bigger and has bolts through it). Is there an easy place to get part numbers for the injectors and rails. I know at least the rails from the donor are also different than my 2019
#14 | |
![]() As for the last part of your question, just get on RockAuto and lookup virtually any year 6gen ZL1 and order HPFP/Line/Injectors and when you order injectors, just make sure they are a matching set (Don't mix nominal flow with high flow/low flow) I don't exactly remember the difference between those 3 injector types, but there isn't a difference in performance, it'll just be impossible to tune a mixed set. Again I don't remember the whole story behind the LT4 injectors but there are a mess of part numbers for them and that particular injector is used on multiple platforms other than the LT4 which is why the "low flow/nominal/high flow" exists. As for the HPFP, as long as you aren't running an upgraded fuel lobe it's a direct swap, though depending on what intake manifold you run there are clearance issues to consider. I don't think the LT1 manifold has issues but the LT2 certainly does. If you run an upgraded fuel lobe (such as a +32% lobe) you'll need a lash cap to shim it. Last, the fuel lines are 3 parts so you'll need 1 of each and it's important to upgrade to the matching LT4 set because the diameter and flow capacity is smaller on the LT1 hardware, the LT1 stuff will work but you'll end up coming up short on capacity if you're really pushing the high end.
