Old 01-20-2025, 07:19 PM   #1
QuirkyTurtle
Drives: 2018 1SS 1LE
2018 1SS 1LE no footwell lights?
Hi all,
Just recently became the owner of a 2018 1SS 1LE after years of lusting over one.
I noticed that the footwells have no lighting whatsoever, which I have never seen in a modern car. This car was involved in an accident sadly (no frame damage) which makes me wonder if that's related.
It also came with a Zl1 shift knob, could that have something to do with a previous accident as well?
QuirkyTurtle is offline   Reply With Quote
Old 01-20-2025, 09:58 PM   #2
QuirkyTurtle
I'm not sure if my images are displaying properly so here are direct links:
https://imgur.com/bYX0z1D
https://imgur.com/Q9C1tds
Old 01-20-2025, 11:36 PM   #3
I think all Camaro models came standard with white LED footwell lighting that activates when the door is opened, and it definitely shouldn't be missing on a 1SS.
As a separate option, GM sells an RGB kit that can be installed next to the factory white lights and remains in sync with the interior spectrum lighting on the door panels, radio and cupholders. This kit is for the ZL1, 2SS and 3LT, and if I'm not mistaken, it requires a radio upgrade to work on lower trim levels.
Old 01-21-2025, 02:35 PM   #4
QuirkyTurtle
Why doesn’t mine have it then? I attached some images. Wish I had a Camaro buddy to compare with haha
Old 01-21-2025, 02:37 PM   #5
QuirkyTurtle
Also I’m planning on doing this along with the illuminated door sills and spectrum door cards. I just need to see which dealership around me knows how to do the software part
Old 01-22-2025, 12:25 AM   #6
Here is a picture of the driver and passenger side footwell so you know where to look for the bulbs and see if/why the stock ones are missing. The default ones that all cars should get is the round white bulb, and the rectangular RGB bulb comes from the extra footwell lighting kit, you should see a cutout for these on both sides.
The software installation has a GM part number just like everything else, any Chevy dealer should be able to pull it up in their system and install the software.
Old 01-22-2025, 12:03 PM   #7
p47dman
Drives: 2024 Camaro 1SS
Just to say, when you add the illuminated door sills, you do not need to flash for just them. They are wired through your door switch and work with no computer upgrades.
p47dman is offline   Reply With Quote
Old 01-22-2025, 01:14 PM   #8
cdb95z28
cdb95z28's Avatar
I'm pretty sure 1SS' do not have footwell lighting standard. I have a 1SS 1LE and my car does not have it.
"KEEP THE FAITH"-Fbodfather
Old 01-22-2025, 01:22 PM   #9
p47dman
I also have 1SS, mine has no footwell lights.
Old 01-22-2025, 02:16 PM   #10
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
I had a 2017 1SS 1LE and there was no footwell lighting. It's probably a 2SS thing.
Bad Anvil Garage is offline   Reply With Quote
Old 01-22-2025, 02:21 PM   #11
Wow, okay then, I stand corrected. Looks like GM spared another $2.50 on two small courtesy LED bulbs and screwed 1SS owners over
Old 01-23-2025, 07:58 AM   #12
nothing_but_troub1le
nothing_but_troub1le's Avatar
Drives: 2023 1SS 1LE 6M
hey we get the white light around the screen so they gave us a little something lol
nothing_but_troub1le is offline   Reply With Quote
Old 01-23-2025, 01:08 PM   #13
p47dman
But my car weighs less
Old 01-23-2025, 07:21 PM   #14
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Not sure if it means anything, my 2SS 1LE did not come with the footwell lights. I bought and installed them myself, no flashing is required just a single wire splice and back-breaking/contortioning work
2016 1LT v6
- Totaled
Happiness: Infinite
