![]() Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
trickle charger - hook up to the engine bay posts or direct to battery in trunk?
We are coming into cold weather, I am going to put a trickle charger on the car. It gets driven once a month at most in the winter if there is no salt out.
Do you install the trickle charger directly to the battery in the rear or to the terminals in the engine bay? The rear positive post is difficult to get to. 2022 Camaro SS 1LE with 15k miles, I hope the battery isn't already damaged from never seeing a trickle charger. |
![]() Drives: 2019 2SS Riverside Blue Join Date: Aug 2011
I put mine on the posts under the hood.
2020 Shadow Gray 2SS
Mine is on the posts under the hood as well, seems to work fine but I was wondering the same... I just started using one about 6 months ago or so, wish I had started sooner however it does seem to have rejuvenated my battery some as when I hook the charger back up it always shows the battery as good now where it used to show it as marginal for the first few months...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
I Put It In The Trunk Its Easy
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Mine is in the trunk. Easy to install.
![]() Drives: Camaro ZL1, Golf R Join Date: Feb 2022
I connect mine to the contacts under the hood, and then run the cord down past the headers on the driver side so it doesn’t chafe on the paint. Those Noco chargers are awesome.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG |
#7 |
Under hood is fine. The trickle mode is less than 1 amp, so a lot of chargers are fine. Just make sure it continues to trickle once it detects full charge.
Doubt you damaged the battery by not using trickle. Deep discharge and frequent start/stop cycling are two common battery killers. Our cars do not have stop/start. |
#8 |
My charging cables have a quick disconnect in the cord, so it's connected directly to the battery. The cable is hanging out of the removeable access panel, so I can quickly connect & disconnect the cable in the trunk.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#9 |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
I keep mine under the hood for 2 reasons.
1) I can just set the hood down (not close it all the way) and the wire runs out without being pinched. I also lay down a microfiber where the cable would be touching the paint. I don't like the idea of keeping my trunk open, or running the cable through it when closed. 2) The power outlet next to my trunk would be a trip hazard when trying to get to my other vehicles, go outside, take trash out, etc...
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
#10 |
#11 |
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
My Z sits for winter from around Halloween weekend to middle May(depending on temps and weather). So since it's 6-7 months, I hook it up in the trunk directly to the posts.
2023 A10 ZL1 "NYTMARE"
#12 |
![]() Drives: 2023 2SS 6 speed Rapid Blue Join Date: Apr 2012
Under the hood for me. -22* this morning in MN, a little trickle keeps things alive.
#13 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
Under the hood and I run the cord thru the opening where the hood latches and then out the grill.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
this thread describes the connection points for under the hood method fairly well.
https://www.camaro6.com/forums/showthread.php?t=540177
