Old 01-19-2025, 08:38 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow Standard vs. X-PORT
QUESTION: Has anyone on taken an old standard KONG port, or standard KATECH port and UPGRADED to the new KONG X-PORT?
If so, may I ask your results?
Would love to see some before / DYNO sheets with mod list.
Old 01-19-2025, 09:17 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Did Kong himself say it was worth anything? It does look a lot nicer even though you would never see it.
Old 01-19-2025, 09:20 AM   #3
SOCAL.M6.ZLE
Yes sir... he says he has done alot of them... I don't recall the power gains, but with my particular set up (boost drop up high) I think I would loose 25rwtq down low and gain 25rwhp up top... I don't recall he exact answer but I will ask again soon. I was hoping to see some end user data, as I continue to consider this...
Old 01-19-2025, 09:26 AM   #4
KingLT1
KingLT1's Avatar
Old 01-19-2025, 09:44 AM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
FWIW Kong and Jokerz will both ALWAYS say it’s worth power with zero proof. I have $1500 in credit card receipts to back up my claim lol
Joshinator99 is online now   Reply With Quote
Old 01-19-2025, 09:55 AM   #6
Sillysspeed
Drives: 22 LT1
How about sell your ported blower and go 2650? Whats the price difference?
Sillysspeed is offline   Reply With Quote
Old 01-19-2025, 09:58 AM   #7
KingLT1
KingLT1's Avatar
About 4 grand.
Old 01-19-2025, 10:03 AM   #8
Smokin19
Drives: 19' ZL1 A10, w/pdr
Gabe, you and I are pretty close on our build. I went with the X-port and I will say this. This car continues to pull even harder in the higher rpm range and I think that is attributed to to better flow thru the SC. looking at our TQ differences your comment seems to make this true. It pulls plenty hard off the line and the SC runs at 15 psi. I run a .660 lift on the BTR cam with a 38% fuel lobe. Bear in mind my dyno was on a Mustang dyno, I will leave it up to you to calculate the difference between that and a Dynojet.
Smokin19 is offline   Reply With Quote
Old 01-19-2025, 11:35 AM   #9
SOCAL.M6.ZLE
No thanks... I consider myself a 1.7L purist, love the instant torque, blower whine, and don't plan to go over 900 wheel, so I can't seem to justify the cost of the 2650.
Now, if I was planning a 1,000+ rwhp build. I would absolutely be looking in that direction, or TT.
Old 01-19-2025, 11:40 AM   #10
SOCAL.M6.ZLE
Yes sir, seems like all the Youtube builds show an approximation. delta of 100 between peak HP and peak TQ. Seen several with my mods, and a proper low side hit 850rwhp and 750rwtq +/-
My aim is for greater efficiency by teasing out as much restriction as possible. My current set up is clearly negatively affected by the blower port, as my boost drops noticeably, from peak to redline, whereas all of the X-port graphs show boost climbing till redline on 95% I have seen.
Although I love 815rwtq, I think the car might actually be faster and my stock clutch and drivetrain may last longer with a little more top and and a little less peak torque.
Old 01-19-2025, 03:57 PM   #11
Sillysspeed
Drives: 22 LT1
They say you lose some low tq with the X port
Old 01-19-2025, 06:19 PM   #12
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Your setup will be faster with an X port. Especially over 6000 rpm. That's really all that matters as long as you have the fueling for the additional airflow.
GM Gen V Calibrator
Old 01-20-2025, 11:57 AM   #13
SOCAL.M6.ZLE
Thank you for the feedback. Thats what I am expecting. If I do the X-Port it will be in conjunction with a low-side... as I am already maxing out my OEM low side...
How much torque do you think I would lose?
Old 01-20-2025, 03:44 PM   #14
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
Do temps benefit any from the X-port over the standard port?
GreenZLE is offline   Reply With Quote
