Old 01-13-2025, 10:06 AM   #1
KyleP_1LE
Drives: 2023 2SS 1LE Camaro
Modifying Driving Modes
Sorry if this has already been discussed, I searched for this but didn't find a post.
Does anyone know if its possible to modify the pre-set driving modes? I have my car set with the custom mode that Chevy allows you in sport mode for the suspension and track for the exhaust. What I would like to do is modify the pre-set so I would be able to set the exhaust to stealth mode faster by just selecting something like touring mode. I have a couple cops in my area that get a real hard on for exhaust and it would be really convenient to be able to just hit touring on the selector mode and quiet up for a min or 2 while your driving by.
I don't like to leave the car in track mode all the time because I prefer the throttle response in sport better for how I like to drive the car but want the exhaust as loud as possible 99.9% of the time.
I've gotten pretty quick going through the menu but if possible I would love to be able to use the selector switch.
Thanks in advance for any help!
KyleP_1LE is offline   Reply With Quote
Old 01-13-2025, 01:30 PM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I believe putting the selector switch in snow/ice mode will put the exhaust in stealth mode. Otherwise you have Tour which would be the most conservative while still having the exhaust valves somewhat open.
Throttle mapping is soley controlled by the selector switch, so when you switch modes to snow/ice or Touring, you'll get a less aggressive throttle response.
N Camarolina is offline   Reply With Quote
Old 01-13-2025, 04:00 PM   #3
wang970305
Drives: 2021 Camaro 2SS
you can install a toggle switch for the NPP fuse. Leave it in the stealth mode
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 01-13-2025, 04:09 PM   #4
Abubaca
Abubaca's Avatar
Drives: 2016 SS
The cops don't like stock exhaust?
Abubaca is offline   Reply With Quote
Old 01-13-2025, 04:16 PM   #5
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
2018 Blue 1LE is offline   Reply With Quote
Old 01-13-2025, 04:19 PM   #6
2018 Blue 1LE
Maybe I misunderstood what you modified.
My understanding is you can modify the vehicle start up for suspension and exhaust at a minimum, if not other things.
Old 01-13-2025, 06:38 PM   #7
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I wish you could cold start in stealth mode… leaving the house early morning for a track day always runs the risk of waking the kids
I didn’t know that stealth mode was active in snow/ice PTM. I’ll try that next time I’m in car. . It would also be nice to select the PTM and then crank the engine.
Dabjbr is offline   Reply With Quote
Old 01-13-2025, 06:52 PM   #8
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
You cannot change individual aspects within each mode, you can only change things separately when using the menu on the radio.
You can, however, use hptuner to determine what the exhaust is doing in the individual modes. You could copy/paste the stealth mode npp tables into the touring mode table and then touring mode will act like stealth mode with respect to exhaust. If you want, I can give you a more detailed guide. I use this method to make track mode open 100% of the time, since it normally closes in 5th and 6th below 4k rpm or something like that.
The only downside is you need and HPTuners MPVI 2 or 3, and it costs $150 to license the module that controls the exhaust.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 01-13-2025, 07:25 PM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
You can start the car with the valves closed if you put the car in Key On Engine Off mode, then go into the radio screen and put the exhaust into stealth mode. This is the only way to do it with the OEM config.
However, with HPTuners you can adjust this by licensing and editing the CCM. I commonly set Tour Mode to make the car start up with the valves closed. I then set Sport mode to keep the valves open until 6th gear instead of 4th(auto trans)(manual cars are slightly different). Then I set track mode to never close the valves. The OEM config still closes the valves in some gears in Track mode for both the 10 speed and 6 speed manual cars.
It's a common request that I get.
GM Gen V Calibrator
Old 01-13-2025, 11:07 PM   #10
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
So to be clear, to do this, what hardware, software and tuner services would need to be purchased? HPTuning newb here.
Old 01-14-2025, 12:13 AM   #11
Hostile_1LE
You need an HPTuners MPVI 2 or MPVI 3 (this is the obdII interface)
The HPTuners VCM Suite (you will use VCM editor) free download from HPTuners site.
HPTuners universal credits to license the CCM ($50/credit, the CCM is the module that controls the active exhaust, and required 3 credits/$150 to be licensed).
I can make you a video guide on how to adjust the exhaust if you like.
Old 01-14-2025, 09:20 AM   #12
KyleP_1LE
This is exactly the info I was looking for, thank you!
Old 01-14-2025, 10:03 AM   #13
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Awesome! Thanks for helping this idiot better understand! Not ready to do it now but I might hit you up in the further. Thanks in advance!
Old 01-14-2025, 02:08 PM   #14
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Whoa guys- I haven't messed with mine in a bit, but you simply pull up the settings for each mode on the radio and change what the default individual settings (steering, NPP if applicable and exhaust). That becomes the default setting for each pre-set Track/sport/snow&ice etc..
You can then easily flip into that setting (like touring) to change to Stealth.
Even in Stealth mode the exhaust valves will open for a few seconds at start up. No other equipment needed IMHO.
Ventmaster is offline   Reply With Quote
