Old 01-10-2025, 11:11 PM   #1
atx_traveler
Drives: blue velvet
Lower shock bolt stuck
What is the secret to hammering this bolt out? I got the top (camber adjustment) bolt out easily enough, but the lower one will not come out no matter what I do. I feel like there must be something exerting pressure on it; the suspension is at full droop with the sway bar disconnected.
atx_traveler is offline   Reply With Quote
Old 01-11-2025, 12:03 AM   #2
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I’m sure you know it’s splined.
So loosen the nut, unwind so that it’s flush with the end of the bolt/threads and then use a hammer to knock it out
Dabjbr is offline   Reply With Quote
Old 01-11-2025, 12:06 AM   #3
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
https://youtu.be/ZdydrFbxeMw?si=RIsiupbeuzKEkQ8T
The bolt looks like the one in this video. But again, have the nut spun out to the edge of the bolt before you hammer it out. Don’t damage the bolt
Use a mallet, something with some decent weight and not just a hammer.
Old 01-11-2025, 02:16 AM   #4
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Just jack a little bit the brake disc up.
It removes the entire weight of the knuckle and brake system on the bolt.
Keep the upper bolt in to keep everything aligned, but have it lost all the way.
Very easy if done right, also dont jack it up too much or it will put force on the bolt again.
You kinda have to find the sweet spot which then allows you to easily hammer the lower bolt out. No force needed at all.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 01-11-2025, 06:23 AM   #5
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Good advice above.
I put the nut on the end to get them knocked lose initially so I don't damage the threads (if you plan to reuse them which you can). I'm also using a small 5lb hammer.
I'm also in the Austin area and have been working on these for 8 years, let me know if I can help.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 01-11-2025, 08:42 PM   #6
atx_traveler
Drives: blue velvet
Thanks everyone. I went to Lowes and upgraded my hammer and that did the job! Amazing what the right tool can do.
