![]() Drives: 2018 ZL1 Join Date: Jun 2020
HP Tuners AFR graph scale question
Finally set up my AEM Wideband in HP Tuners, what range should I use for the graph?
I currently set the low at 10 AFR and the High to 18. A friend told me I should be at 0 and 30 so it winds up in the middle. Where should I set it? Thanks in Advance |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Set it wherever you want it. Why does it even matter?
GM Gen V Calibrator
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I'd suggest changing it to Lambda and setting your graph from 0 to 2.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
THANKS!
