1LE splitter question
Will a 1LE splitter fit on a standard ZL1?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
![]() Drives: Z06 Join Date: Oct 2021
I think you have to buy the 1le grill too, right?
Change the grill!, that’s costly!! , question is why??
![]() Drives: 2022 ZL1 Join Date: Sep 2024
The lower grille has slots in it that the splitter hooks into.
#7 |
Thank you Al Oppenheiser!
Depending on what you swap, you may have to change other parts to make them fit, for example: front bumper cover + dive planes + DRL-delete. Also, factory paint on the 1LE aero is matte vs. the WA384A mosaic black metallic that comes on the non-1LE coupe and convertible.
#8 |
I would sell you my splitter but I'm not sure when I can get to it
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#9 |
I have been through this and have had all the same questions
Now that I have done it I can share Front Splitter from the ZL1 1LE will fit but only if you change the front grill. (you can use the stock bumper cover) There are tabs that the splitter slips into under the front of the grill that the stock ZL1 grill does not have. Then you have your winglets on the sides of the splitter that you need to remove your front bumper cover and cut the markings that are on the back side of your front bumper cover to slide the clips in to mount them. While you have your bumper off and you want the drive planes you would need to cut the marking out to fit those on also. |
#10 | |
#11 | |
and then did what for the winglets at the end of the splitter? do it right and GOOD LUCK! |
#12 |
not to beat a dead horse but I attached picture of my conversion for the splitter part of the project
Stock grill has no openings on the bottom for the 1LE splitter to clip in (i guess you can cut the tabs and two way tape them in place) and then you need to cut and modify your bumper for the winglets. |
