Old 01-04-2025, 10:21 PM   #1
SpartanSS
Drives: 2023 Camaro 2SS
Antigravity battery alternatives
Just wondering if anyone has looked into any alternative to the almost $1k antigrav batteries?
Found this on Amazon - just not entirely sure if this would work for Camaro’s
https://a.co/d/42H9RNf
SpartanSS is online now   Reply With Quote
Old 01-05-2025, 09:19 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I think you would want a 100ah not a 50.
Old 01-05-2025, 10:03 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m running the Antigravity 40AH one in my Camaro now and it’s OK, would probably do a tick bigger next time around. 50AH is fine on an NA SS but on supercharged cars if you want to run your intercooler pump and cooling fan at the track I’d go a little bigger.
Edit: I’ve never tried the Amazon lithium batteries but it’s probably made at the same factory in China as Antigravity.
Old 01-05-2025, 10:30 AM   #4
buckwam
Drives: 2021 camaro 1ls
Would the 40AH work well for the 2.0 turbo?
buckwam is offline   Reply With Quote
Old 01-05-2025, 01:48 PM   #5
Joshinator99
Moderator
I’d assume so since I’m also assuming you’re not drag racing the car and trying to cool the car down between rounds using the battery power.
Old 01-05-2025, 02:32 PM   #6
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
I had the same thoughts recently.
1. Lifepo Batteries can use nearly 100% of it's capacity, unlike AGM which only can use ~50% before voltage drops too much. That means a 50AH is more than enough.
2. Most Lifepo4 Battery sellers even say, they are not made for cars.
The reason is the sensitive in built battery control module which cuts power, if the temperature or voltage gets too high. You don't wanna loose your fuel pressure/ignition under WOT nor the power steering.
3. very sensitive against temperatures. You can't use them if its colder than 32°F and 140°F is often the upper limit.
4. and I've heard, they like to explode if they are not treated right. + needs specific charger
SpeZ is offline   Reply With Quote
Old 01-06-2025, 11:45 PM   #7
Scott12
Drives: 2023 Camaro
Would never spend that kind of money on a battery, the 1k one that is.
Scott12 is offline   Reply With Quote
Old 01-08-2025, 12:24 AM   #8
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
This looks like an alternative
Old 01-08-2025, 06:43 AM   #9
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
What's wrong with a regular old lead acid battery?
cadyshac is offline   Reply With Quote
Old 01-08-2025, 07:21 AM   #10
Joshinator99
Moderator
An additional 30 pounds of weight.
Old 01-08-2025, 11:09 AM   #11
KingLT1
KingLT1's Avatar
Yeah, but it's where you want the weight right over the right rear tire. Now if the battery was under the hood, I would have had a lithium a long time ago.
Old 01-08-2025, 12:26 PM   #12
Joshinator99
Moderator
No argument there.
Old 01-08-2025, 01:50 PM   #13
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
There are better anti-grav batteries than this out there more suited for the vehicle. And weigh less specifically designed for weight savings in terms of racing.
Such as:
https://4xspower.com
There is some dependencies as well when it comes to our cars: Amperage Hours among other things. Might want to familiarize yourself with our stock battery statistics first before you jump into randomly picking one of these things up. And you won't find a good one for our cars for $200. They don't exist.
If I remember right these are going to be the closet thing to match the SS you might be looking for, but as I said you won't find anything for the price range you are looking for:
https://4xspower.com/products/li-s925
https://4xspower.com/products/li-s1200
Old 09-02-2025, 03:46 AM   #14
neskihe
neskihe's Avatar
Drives: 2000 Camaro Z28
Such as:
valuable information, thank you, I also think that when things are good, they don't look for better
neskihe is offline   Reply With Quote
