![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
Which set of headers (listing headers with know problems)
All headers seem to have problems but which ones are the least problematic vs price or value
CSP - seem to fit the best, but still have issues with the wiring harness having to be moved. Never in stock and $1600 with off-road connection pipes Kooks - cause false knock, wiring needs to be moved, rubs motor mounts, have to drop starter and sits very close to the starter. Can buy CSPs clone version with connection pipes for $1350 ARH - had arh on my old car, had burnt wires. Price lol TSP - fit issues with steering column. Some have to dent the headers or just have it rub the steering column. Also no rear 02 bung on the cats, so no putting wideband. Not sure if the high flow cats are good, not sure if the my are 200 or 400 cell. Very reasonable price 1k with cats. Speed engineering - fit issues, clamps leak, cheaper metal, not cat options but damn cheap and since the all have problems why not. Very feasible price $750 ish with 3” x pipe going to axle back. Stock manifolds - give up on 10-20 rwhp on a bolt on car, no cool exhaust noise but no cost and problems. I’ve search many times just wanted some fresh opinions.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph Last edited by vince3; 01-06-2025 at 12:54 PM. Reason: Missed a word |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
#3 | |
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
![]() Drives: 2017 Camaro SS Join Date: Feb 2023
I just put the stainless power headers on and they were pretty easy to install and they appear to have really good clearance all around. No starter removal, motor mount removal just the middle of steering shaft and passenger valve cover and 2 spark plugs on each side. I thought it went pretty well compared to installing a hurst shifter the previous week.
#5 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I have had Kooks on my 2017 SS for almost 4 years now. Other than moving the passenger side wiring harness which you would need to do for all headers except for the factory manifold, I have not had any problems. I found that they fit pretty much perfect and had plenty of clearance of everything.
#7 |
Is it worth getting the jet-hot coating? Does it help with the wiring harness issue?
#8 |
All headers require moving the harness over. OP, you are being a bit petty imo.
Yes the ceramic coating is worth it.
#9 |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Running "The Online Store" LTH's on my car. The ones I got needed to have the flange on the passenger header squared up. Had this done at local machine shop, they weren't even going to charge me for it but I tipped the guy $100. The collector connectors also need to be hacked off, had V-Band's put on and mated to the factory Mid-pipe, that was another $150. Unless you buy a LTH/Mid-pipe system, I think there's going to be some cost for exhaust work with any header setup to mate up to existing mid-pipes. No rubbing, no wiring harness issues, no dents needed. Install was a breeze for these, did them by myself. Had to have my wife hold the Driver Side header when I passed it up through the bottom because it would have fallen on my face otherwise. I did remove the steering shaft for that side to install. Replacing the shaft was easy.
For what most would consider to be crap headers, I'm very happy with them. At $599 they were relatively hassle-free. Now we'll see how many years they last.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#10 |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
As from what others have said, all headers require moving the harness. You do get what you pay for, and thats why I only recommend Kooks (What I personally chose) ARH, or CSP.
With other brands you can get lower quality steel, worse fitment, bad QC, poor customer service, and more. I always suggest a heat coating as well, just for long term durability. Ceramic wires are also a benefit for this reason. I am a little confused on what you mean by the stock manifold gives you 10-20hp? How does a stock part just randomly gain you horsepower?
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
#11 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#12 | |
![]() Drives: 2020 Camaro SS 1le Join Date: Nov 2023
I've installed just about half a dozen sets on both ZL1's and SS's and I've never had any problems with any of those brands. A majority of the cars I've done have been speed engineering. Never any fitment issues, clamps work as expected. I personally have them on my car as well, I was able to get them for 400 bucks brand new off Facebook. Couldn't turn that down...
______________________
2020 1SS 1LE M6 Riverside Blue Metallic Forged Bottom End | KATECH PORTED HEADS | HCI | GPI LT NFC |
#13 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
ARH
Kooks CSP Any other brands are not consistent with fitment. Burnt wires are the fault of the installer. Also, you should use MSD plug wires as they have no issues with touching the headers and you can bend(curve)the plug side to shape them as needed. They are designed to do this. We never have any issues with wires. We also move the wire harness, on the passenger side, to the other side of the coolant tank and use a loop tie to secure it to the frame and away from the header. Coating has its benefits but with the stainless steel used by the headers I listed, coating is unnecessary for street cars. If you're road racing, then coating them is much more important. You will have ZERO issues with quality uncoated headers on the street. Have your tuner turn up the fans to keep air flowing through the engine bay even at lower coolant temps.
GM Gen V Calibrator
#14 | |
Did you ever fix this issue?
