Old 12-30-2024, 08:53 PM   #1
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Question clutch pedal safety question
Car will not start without the clutch engaged.
I wanted to test a theory, but was unable to unplug the connector on the clutch pedal. Anyone done that yet?
Can this safety be bypassed through the OBD port?
Can any or all of the vehicle start up safeties be bypassed via OBD access?
2018 Blue 1LE is offline   Reply With Quote
Old 12-31-2024, 01:52 PM   #2
ctrlz
Based on this ebay listing the clutch position sensor appears to be the black connector. I suspect at full depress of the pedal the two wires are connected. If you get the connector off, you could test with a shorting wire on the harness.
I do not think you can override this through software.
https://www.ebay.com/itm/28529848881...Bk9SR_i3yOCDZQ
Old 12-31-2024, 05:11 PM   #3
2018 Blue 1LE
I am not trying to override it, just using it as a signal for "other" purposes.
Old 12-31-2024, 05:27 PM   #4
ctrlz
Measure the voltage across the connector once it's unplugged. If it is something simple like 5 or 12 volts on/off, you can probably setup something to use the "signal" when current flows through the circuit. I doubt it's a digital signal since it's used for startup.
Old 12-31-2024, 11:14 PM   #5
2018 Blue 1LE
It is just in a spot that is not easy access.
Need to be a contortionist and small.
