![]() Drives: 2018 grey 1ss Join Date: Aug 2018
Oil pan Removal for oil pump replacement
hello people, im currently replacing my oil pump due to oil pressure issue, im currently at the state where the timing cover and oil pan has to come off. do any have any advice for removing both? how did you remove the rtv sealent?
#2 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2. Once the bolts are removed, as mentioned... the existing RTV holds tight. You will need to pry off both covers gently but with force. If you have a thin metal putty knife, you can work your way around with a hammer cutting some of the RTV seal, which will make prying easier. Once the covers are removed, its a careful use of flat blade to remove all the RTV from both the block and cover. I think its best to use a slightly dull blade as to not gouge the aluminum surfaces. 3. You don't need to remove 100% of all the residue, just enough to get a clean grip o the next application. 4. Good luck a few photos of my surface attached for reference.
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
update: just removed the timing cover next up is the oil pan, gonna rain the next few days on top of work so next week be at it will keep yall posted.
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
Any update? How did it go?
i will be resuming the job in two week after a vacation!!
#7 |
Unacceptable... this is taking far to long...
#8 |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
FWIW, most hardware chains sell plastic razor blades. I used these for cleaning up the RTV surfaces, and a soft brass brush for the stubborn shit in the grooves/dowels. As long as you aren't aggressive with the brushes, you won't mar the surfaces. Even on an engine stand with an open floor, the oil pan is an absolute pain in the ass to pry off. I can't even imagine fighting it with the engine in the car. Would rather have plastic/rubber gasket for the pan than RTV here.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#9 |
![]() Drives: 2017 Camaro 1SS Join Date: Apr 2025
I'm at the same point. Timing cover is off, gonna start on the oil pan next. Also looking for the simplest way to do it. As far as I'm understanding, gotta drop the steering rack, subframe and lift up the engine? All just to get to that pickup tube bolt. We looking at dropping the pan completely? Or is there an easier method?
(First timer here) |
#10 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Ya I've dropped my pan a few times. Pull the steering shaft, then the plugs for the rack and the 2 main bolts on the subframe. I let it hang there to get the front pan bolts, pull motor mount bolts, pull the crank pulley, water pump, factory catch can, remove front cover. Then I lift from the trans, remove oil cooler, remove pan. You wont have to drop the subframe as i did the first time removing this. If it doesnt slide out the crank may have to get rotated as the counter weights can block the pan from sliding back
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
