Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I was speaking to a new client yesterday, and he had been seeing 300F on his oil temps with a 2019 ZL1! I am excited to see his results with our Stage.III Oil Cooler package but it had me thinking...
What are the HIGHEST Oil Temps you have seen on the track?
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
![]() Drives: 2021 Camaro 1SS 1LE Join Date: Aug 2014
I haven’t been monitoring oil temps, like I probably should …. there’s only so many things you can look at when going 9/10th.
But, I have also heard of others saying they hit 300F. While I realize that today’s synthetic oils can handle higher temps, I would throw money at a solution if I saw more than 260F. Just my opinion. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
288°F on a 90 degree day
![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
290-300F at Road America if it's warmer than like 70F. A10.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
298*, Pitt Race, SS 1LE with A10. I have a C&R oil cooler to install this winter.
"KEEP THE FAITH"-Fbodfather |
![]() Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30 Join Date: Dec 2021
290° and then let off the throttle. After adding an oil cooler max temp was 257°. Running an universal Mishimoto oil cooler, DIY custom built.
HPTuners shows 311° as limit, if temp is reached it alerts. For myself, everything above 270° is too hot. (ZL1, A10 with 1LE struts and aero + impact bar removed) |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
Holy crap I did not expect to see an SS 1LE hit those temps. From my understanding 270 degrees is the SS high but maybe because you have an A10 it’s higher?
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#8 |
Yep, the A10 keeps both the LT1 and LT4s more wound up.
#9 |
I wonder if this is why later MY LT1’s have been blowing up more at track recently. Insufficient oil cooling for the A10 cars and the A10 wasn’t available until MY 2021.
#10 |
Interesting. I wonder if this is only possible to reach on a manual where you have full control. Back when it was a 95F day at Road America, I would reach 300F within 2 laps and the ECM/TCM would start short shifting once it reached 300F. Using Pi Toolbox to analyze my PDR data, engine oil temp never exceeded 300/301 F. This is the only time I've had abnormal transmission shifting events. I changed my transmission fluid myself last time, so I know it's properly filled.
#11 | |
#12 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#13 | |
The ZLE pan has a shorter standoff tube than all of the other A10 pans, so it already takes less fluid. I can't exactly find how much less fluid it takes at the moment. I'm not using the 212F level check as a result because the ZLE pan did not exist at the point those instructions came out and I don't want to be under filled.
#14 | |
Facelift, 2019 and newer running a cooler thermostat 167F. So it's primarily not really about the fluid level.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
