![]() Drives: 2018 ZL1 1LE Join Date: Jan 2024
ZLE brakes squeal
Hi everyone,
Picked up used ZLE. Brakes are squealing, I believe both in the front and one in the back, sooo annoying, looked at the pads, lots of pad life left, not even remotely close to wear indicator. Tried braking hard after a wash thinking maybe brake dust but no buano. Now if I brake moderately then no noise or if I brake hard no noise. Just at certain pedal pressure when coming to a stop. Read all kind of stories on forums, anything from pads replacements to more aggressive to scrub the rotors to full brake replacements.HELPPPPP
Before replacing any hardware, try burnishing the brakes.
Seen that before. Will try this list to the T to see if it helps.
That Camaro Life
![]() 2018 Camaro ZL1 1LE 2017 Camaro 1SS - SOLD 2019 Camaro I4 2.0T - SOLD 2024 Mazda CX-50 - Winter beater 2021 Dodge Durango R/T TnG - SOLD 2019 Mazda 3 - SOLD 2013 Dodge Journey R/T - SOLD 1985 Porsche 944 - SOLD 2011 Volkswagen Jetta - SOLD 2000 Honda Prelude - SOLD 2007 Tayota Matrix - SOLD 2004 Mazda Protege - SOLD 2004 Pontiac Vibe - SOLD 2000 Ford Focus - SOLD |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
It's normal. High performance brakes. You're in the abrasive mode of friction. Bed in will put the brakes into adherent friction mode but regular street driving will put ya right back into abrasive mode. Arpad got you hooked up. But the GM procedure is a little excessive. Read this then watch the below video.
www.centricparts.com/media/wysiwyg/technical-bulletins/TECH_BULLETIN_C22-01.pdf Watch this for the best info on bed in: https://youtu.be/pdPX6rzuINc?si=iRynEgwQSfl775Ye Embrace the squeal. #becauseracecar.
"KEEP THE FAITH"-Fbodfather |
#5 | |
Thank you!
That Camaro Life
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Nice video cbd! It's a little long but if anyone else looks, watch thru to the end. Lots of good info there.
