![]() Drives: 2018 ZL1 1LE Join Date: Jan 2024
Roto Fab
I picked up used Roto Fab with oiled filter, looks in overall good shape, but I do not like anything oiled. Is oiled filter better than dry for these Roto Fabs? If not, Roto website is a little confusing, trying to buy dry replacement.
There is no significant performance (flow) difference between their oiled and dry filter elements. I've had both and also prefer the dry one.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 12-28-2024 at 11:31 PM. |
#3 | |
That's what I thought, I'll swap to a dry one. Got a part number by any chance? Their website is rather confusing, I believe I found the correct one off another website but would be nice to confirm.
That Camaro Life
![]() 2018 Camaro ZL1 1LE 2017 Camaro 1SS - SOLD 2019 Camaro I4 2.0T - SOLD 2024 Mazda CX-50 - Winter beater 2021 Dodge Durango R/T TnG - SOLD 2019 Mazda 3 - SOLD 2013 Dodge Journey R/T - SOLD 1985 Porsche 944 - SOLD 2011 Volkswagen Jetta - SOLD 2000 Honda Prelude - SOLD 2007 Tayota Matrix - SOLD 2004 Mazda Protege - SOLD 2004 Pontiac Vibe - SOLD 2000 Ford Focus - SOLD |
#4 | |
The replacement dry filter element is sold under part number 1013-5014, see here.
#5 | |
Thank you! For some reason says for SS 5th gen. But on other sites 2010-2024 lol. They must of been using same cone since the beginning.
That Camaro Life
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
As stated no significant difference in performance on a stock vehicle but oiled can be serviced forever. That makes oiled superior in my opinion. I would also say there is a point where oiled likely DOES flow more than dry since the Big Gulp which is designed for high HP applications only comes with an oiled filter. For stock applications though, the standard Rotofab comes with both filter options since both flow more than enough air for a stock engine.
#7 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Might explain where the extra 18 HP comes from in the Blackwing LT4.
#8 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#9 | |
Coupe Newbie
https://www.camaro6.com/forums/showthread.php?t=540899 When I had my ZL1, I experimented with cutting the bottom of the airbox out. Got more supercharger whine for sure but also got higher IATs at idle from sucking in hot engine air. https://www.camaro6.com/forums/showthread.php?t=541269 Unfortunately, there's not enough material on the fender side of the ZL1 air box to make an opening like there is with the BW.
#10 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I preferred cleaning over replacement with my choice.
#12 |
Maybe the C7 Z06 has more filter area, if not then I don't know but there's just no way a dry filter is going to flow as much air as oiled cotton assuming everything else is equal.
#13 |
FWIW I had oil residue in the intake pipe section between the filter and the MAF with a brand new oiled filter after 2-3000 miles, so I'll stick to the dry one for the time being. Last thing I want to see from an intake is oil contamination on the MAF.
#14 |
Had my oiled filter on my car since the car had 400 miles on it, now at 12K miles, no oil residue in my intake pipe section. There should never be any oil residue if oiled properly. I've never heard of one doing that when it was purchased new, I have seen people that serviced an oiled filter themselves and used WAY too much oil that caused that issue. This is an old wives tale that has circulated the internet for decades now. If this were a known issue then none of these companies would be in business selling them and none of the tuners/shops would be using them in their builds.
