Old 12-22-2024, 10:17 PM   #1
Chev133
Drives: Chevrolet Camaro zl1
ZL1 canards
Hi,
Has anyone used the Anderson composite ZL1 (non 1LE) canards (dive planes) on their 6th gen ZL1 & have any photos? I’d like to leave the DRLs & don’t want to spend over $1000 on something that doesn’t fit right.
Thanks. Anthony.
Chev133 is offline   Reply With Quote
Old 12-24-2024, 09:39 AM   #2
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
I personally do not have experience with these, but there are a couple people I know that have a regular ZL1 that put the canards on and you DO lose your DRL's. I like the DRL's so I can't justify putting something on my ZL1 that really will not benefit me since I never track it or drive it past 130-150 mph enough times in order to get the "function" out of them. I understand some like the canards for looks, just not for me. Hope this helps?
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 12-25-2024, 06:14 PM   #3
Chev133
Thanks, I’m in Australia & we never got the 1LEs. The ZL1s we got actually had the DRLs deleted! I put them back but now I’d like to get the full 1LE front to be different from all the others that are here. They made 375 (converted from LHD) 75 went to NZ. All were ZL1s.
Old 12-25-2024, 06:59 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
I bought some aftermarkets that don't require removing this and that coated them with a good Carbon Fiber wrap and heated them with heat gun.....Not exactly the same appearance but much less problematic.... Paint did not stick well so I wrapped em and its much better...... Just a couple small screw holes to drill in the Lower and they are so small for the screws you could ignore them if ever removing..... Check these...Good Luck
https://zl1addons.com/collections/ca...l1-dive-planes
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
christianchevell is offline   Reply With Quote
Old 12-31-2024, 08:55 PM   #5
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
I went with the OEM dive planes and complete upper and lower grilles and spoiler which requires you to take your front bumper off to install. You do however lose your DRL's and the OEM look Way better then the the After markets planes out there
IMCWORTH is offline   Reply With Quote
Old 01-01-2025, 09:17 PM   #6
TomTime
TomTime's Avatar
Drives: Chevrolet Camaro ZL1 Convertible
IMCWORTH, I know this is off topic, but I see that the 1LE wing will fit on the convertible, even though manufactures of these wings state they will not.
Good to know! I want to put one on mine.
If you don't mind saying, what manufacture is that rear wing from?
Tom.
2018 Chevrolet Camaro ZL1 Convertible, Mosaic Black Metallic.
2024 Chevrolet Silverado 1500 Crew Cab Z71 Trail Boss, 3.0 Duramax, Dark Ash Metallic.
One for fun and one to get things done!
TomTime is offline   Reply With Quote
Old 01-01-2025, 10:21 PM   #7
IMCWORTH
IMCWORTH's Avatar
Tom.
I have seen a couple of different manufactures fit on the convertible. however there are some extra holes on the trunk that you will need to plug. or have welded shut. and then also your AM/FM radio wont work because of the antenna that is in your spoiler. But there is a way to make it work if you need to. but to answer your question this is the carbon fiber made by Extreme Online Store also has a rear camera option available that other manufactures do no have.
https://extremeonlinestore.com/colle...31406150418499
https://extremeonlinestore.com/produ...41715545211050
