Old 12-22-2024, 06:43 PM   #1
LancevanceZLE
Drives: 2019 ZL1 1LE
X pipe check engine light?
Will a catback exhaust and x pipe that retains the secondary cats cause a check engine light for a manual?
Can't have a tune/check engine light due to California smog.
LancevanceZLE is offline   Reply With Quote
Old 12-23-2024, 07:58 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No, it shouldn't.
KingLT1 is online now   Reply With Quote
Old 12-23-2024, 09:15 AM   #3
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
No because you will be retaining 100% function of the required emissions equipment and your o2 sensors will be untouched.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is online now   Reply With Quote
Old 12-23-2024, 02:31 PM   #4
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Deleted.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
