![]() Drives: 2018 ZL1 1LE Join Date: May 2022
LT4 Cammed Reliability?
Hey all!
Recently I have been presented with an opportunity to have my car cammed and tuned for extremely cheap by a reputable and trustworthy shop (I'm not going to get into details, but I'd essentially be paying for the cam kit alone). Naturally, this has tempted me, but I need to consider the long term consequences of something like this. Does anybody have any experience with long-term reliability of a cammed LT4 with proper supporting mods? I plan to keep this as a forever car, and don't want to deal with replacing valve train components as a maintenance item, or popping an LT4. For reference, if I were to do this, I would install a BTR Stage 2 or Stage 3 cam, and perform all necessary supporting mods (cam, Johnson lifters, BTR titanium valve springs/retainers, BTR pushrods, etc). If I do this, is there no chance this car sees stock-ish reliability? I'd like to hear people's honest thoughts before I undertake something this big. |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Valve springs will need to be replaced at an interval based on the lobe ramp rates. Anywhere from 15k to 40k+ miles depending on the cam profile.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#3 | |
Anything else though? I will admit I drive my car very hard (spirited street driving and a little bit of amateur track use), and would not like to blow a motor if I do this lol. |
fo'shizZL1
I daily drove my last car about 40k miles with a cam. No issues, just a lot of good times!
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
I’m at 18k miles since cam and no issues, basically did upgrades with the kit as to what GPI recommended in the kit options and we installed ourselves
Mild cam will get you stock-ish reliability. I would do a BTR stage 1. It sounds great and drives as close to stock as you will ever get. Stage 2 works but starts to push on the converter at idle. Manual car would be ok. Either way, you don't need a lot of cam to make power.
#7 | |
I do drive my car extremely hard on the street (spirited drives every single weekend in the mountains, often times for several hours, and the occasional track day). |
#8 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I would also look into a BTR Stage 1.
If you get a chance listen to this podcast, lots of great info. https://youtu.be/2SIFz7CpxLA?si=bzLHXhodw3CtWS7x If you want the short version start at around 2h20min
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#9 | |
#10 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Just to give you some perspective OP, I make the power I am in my signature with a stock sized LT1 cam with a 32% fuel lobe from BTR. There is still space to go with more power too by going 30+ XDI injectors and a ported blower. As of current though it's a really good amount of power for the street and the tuning on it was relatively easy, but it will run with the stock tuning if necessary.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
723 HP/ 765 TQ Last edited by ZLRob; 12-20-2024 at 02:39 AM. |
#11 | |
![]() Drives: 22 ZL1 M6 Join Date: Oct 2018
22 m6 zl1. cammed, headers, etc
#12 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
My car makes some beans with a BTR Stage 1. Been 5.1 60-130 full weight on 20’s with a 270 pound driver in 75 degree weather.
#13 |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
BTR will do you right, ask them most of your questions, 1 thing put a katach billet oil pump on, that should be 1st and for most
#14 |
Super Stock
I have some but it's easier to send through FB messenger or something the likes. Private message me and we can figure out how I can get it over to you.
BTW, I use ghost cam on my tune so it sounds different than what OE would otherwise sound like. It's not a stable idle because of that. I also cannot stress enough to throw on an LME billet tensioner on it as well. The OEM one is a ticking time bomb waiting to cause damage if you run a GM oil pump or Katech.
723 HP/ 765 TQ |
