Old 12-16-2024, 02:08 PM   #1
vince3
Drives: 2022 Vivid Orange LT1-M6
FBO minus headers
I’m thinking about doing full bolt ons minus headers due to so many install,
and fitting issues with headers. It seems like they all rub or burn up your starter or main wiring harness. If you do get headers with cats, the cats melt or you have to go catless with increase noise.
https://www.camaro6.com/forums/showt...535959&page=10
This user Alpha1LE hit near 490 rwhp and another user got around 480 rwhp, then swapped to headers and didn’t gain anything. Do you think the stock cats will also melt?
If I do headers, the safest seems to be CSP headers with catless connection pipes, wrap the starter and move the wiring harness and install a magnaflow x pipe muffler where the factory x pipe is.
I know I’m rambling at bit, but any thoughts on this?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 12-16-2024, 02:24 PM   #2
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Yeah, OEM headers are excellent and long tubes won't get you nearly the gains they used to with the old log-style cast headers. Removing or relocating cats isn't a good idea, and isn't legal. Unless you're going full race car I wouldn't touch the oem exhaust.
Old 12-16-2024, 04:38 PM   #3
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
I can't see you getting past 450-460 whp without headers. Probably will be closer to the lower end of that number.
You don't have to worry about melting the cats. That's a ZL1/supercharged thing. That would probably happen on oem cats after a certain horsepower number (like 700-750whp is when I'd start to worry).
The fitment issues and burning wires are mainly due to using cheap headers and/or getting them installed at a shop that does not take precautions to not melt wires. I get it though, the burning of wires would be the number 1 thing I ask a shop about. I've also seen it happen on these boards one too many times. You'd think there'd be plenty of room in the engine bays of a push rod V8 but not this platform.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 12-16-2024, 05:38 PM   #4
vince3
https://www.camaro6.com/forums/showt...=559372&page=3
Here is a pretty detailed post of someone who got 480 rwhp with no headers and cat deletes. Then they added catted headers and lost power.
Old 12-16-2024, 06:29 PM   #5
EliteLT1
EliteLT1's Avatar
Drives: 2022 Camaro LT1
I did a bunch of bolt ons but haven't touched the exhaust yet. I got 462 hp and 456 lb*ft on E85. I didn't measure the ethanol content before dyno, but probably around 75%
The mods are CAI, 95mm TB, LT2 manifold, flex fuel sensor
I want to add headers and mid pipes at some point but working on suspension now
https://www.camaro6.com/forums/showthread.php?t=617315
EliteLT1 is offline   Reply With Quote
Old 12-16-2024, 06:48 PM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
headers might not add alot of power but they do sound so good on these cars especially with full exhuast i got compliments everytime i go to to the track about how my car sounds
Old 12-16-2024, 07:23 PM   #7
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Completely agree. I have Kooks headers with the Borla S-Type. The sound is amazing.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 12-16-2024, 08:29 PM   #8
ChibbMD
Drives: 2022 SS 1LE
I have almost the exact same mods and am in the exact same range of HP and TQ. I did buy some Kooks 1-7/8 headers off a member mainly because they were a good deal and exactly what I was looking for. Haven't gotten around to installing yet, but looking forward to knocking that out soon. I'll have to report back here with results.
ChibbMD is offline   Reply With Quote
Old 12-16-2024, 09:13 PM   #9
vince3
That would be a good comparison to see if headers help with when you have the supporting mods
Old 12-17-2024, 07:55 AM   #10
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
No competent tuner is going to lose power by adding headers to the LT1. That said, they don't provide a lot of extra peak HP. The gain is in the mid range area and they do make the car faster. But, if you don't want to deal with headers, you can still get a nice bit of performance out of the LT1.
Add a green drop in filter, port the stock 87mm TB(or get the Soler 91mm eff unit), have the stock LT1 intake manifold ported(or add a ported LT2 manifold) and add a Flex Fuel sensor. The performance gain will be noticeable with these mods.
GM Gen V Calibrator
Old 12-17-2024, 08:58 AM   #11
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
Is there any gain to be had by removing the secondary cats? I understand they were only put their to comply with California's draconian emissions rules (which I couldn't care less about).
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 12-17-2024, 02:46 PM   #12
vince3
2” kooks with connection pipes for $1360 or 2” speed engineering with x pipe for $800ish?
Old 12-17-2024, 04:36 PM   #13
GreyGhost702
Drives: 2019 Camaro 1SS1LE
The only reason a factory cat would melt is if the engine was tuned poorly or catastrophic failure. You'll be fine on factory cats for a good long while. ZL1, ZR1, Hellcat, GT500, GT350, all vehicles north of 500hp on factory cats with full warranties. The Big 3 wouldn't stick their necks out if the parts wouldn't outlive the warranty period. That said, nothing lasts forever.
Don't get hung up on a number, you just end up chasing or end up disappointed.
As far as getting hung up on LTH's, if you're new to the modding game, nothing ever goes the way it should in a build. There are things you can do to mitigate heat issues from LTH's, just don't wait to have issues and take those precautions. I haven't had any issues with mine so far, maybe because I don't daily my car or because I live in a cooler area, or both. Just lucky. Who knows.
For as good as parts makers are these days, sometimes there's little flaws you have to work through. My LTH's were of the cheap kind and I had an issue with my header flange and had to spend $100 at a machine shop to be fixed so they installed properly and had a good fit. Par for the course, and small beans in the grand scheme. They work beautifully now, and a part on the car I don't even think about since it doesn't cause me problems. The increased noise is such a beautiful sound. 'Merica.
If you're going to avoid specific parts to avoid the pains of dealing with the unforeseen, you'll leave a lot of potential on the plate. With what you're doing right now, no cam and no ported heads, LTH aren't going to pay a lot of dividends. You get into a cam and ported heads, it's going to leave some of that potential on the table, but you'll still make good power and track times. Get into FI, now you're barking up a whole other tree, and a lot more of that potential gets left behind. At a certain point, the OE system will become a restriction to the point where it just won't be safe to push more boost.
If you're not cracking the seals on your engine, the OE exhaust will work just fine with what you want to do.
No power to be had anywhere behind the manifolds. Purely exhaust tone and volume preference. If I could chain amplifiers to my exhaust and crank them to 100% I would, that's what I like. I want my Grandpa who passed away 6 years ago to know when my car starts. Goats tip over when I drive by. Karen's grab your pearls and hold the china, I turn over in Track Mode.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 12-17-2024, 05:45 PM   #14
ChibbMD
Drives: 2022 SS 1LE
My research suggested that 2" headers were a better match for the supercharged ZL1 and 1-7/8 was all you need for the naturally aspirated LT1. Bigger is not always better.
