Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
P00E9 code
Anybody dealt with this one? I see it's the IAT3 sensor as far as the description of it goes, but I was under the impression that these didn't have an IAT3 and technically IAT3 was actually a computer calculated PID using IAT1 and IAT2 and combining them.
This code has popped up on me twice. The way it has triggered is by the following: after two hard starts with full E85 using remote start then re cranking it using the push button start. So by the third try after the E has stopped killing the car, it stays running, but the code has popped up by then.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
Super Stock
Crickets eh?
834 HP/ 840 TQ |
Best reference I could find for camaro:
https://www.camaro6.com/forums/showp...81&postcount=6 I think the "MAT" is also a "MAP." These sensors attached to the intake manifold now typically report both temperature and pressure. |
#4 | |
Super Stock
834 HP/ 840 TQ |
A scan tool should let you see what the MAT is reporting. If the data is out of whack, it might contribute to the stalling.
Super Stock
You know that's the thing. I check info using my iDash and the IAT1 appears fine at the freeze frame error. I don't think it's displaying IAT3 information when i check freeze, however, I'll have to recheck that and see what's going on. Worse comes to worse I'll just check the data over with a regular scan tool.
834 HP/ 840 TQ |
#7 |
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
I believe the remote start fails automatically if the check engine light is on. They don't want the car sitting there idling when something is wrong with it.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
