![]() Drives: 2018 ZL1 Camaro Convertible Join Date: Oct 2021
Oil Weight?? New Katech Oil Pump
I have a 2018 ZL1 with a new Katech oil pump installed. Should I change the recommended oil weight?
I was told to run 10w 30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
He said 10W-30?
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
We recommend the updated 0W40 spec oil in most stock bottom end builds.
![]() Drives: 1985 Oldsmobuick Join Date: Oct 2012
I meant to say "WHO" said 10W-30.
Jannetty Racing recommended 10w 30 with the new Katech pump. I have no mods at all. Everything else is stock
So Katech Mike,, 0w 40 for everyday driving ??? |
#7 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
#8 |
#9 |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
During these Winter months when I am not driving the ZLE as much as I like and since I am not tracking the car until Feb/March... I switched back to the Amsoil 0W-40 Powersports Formula. This oil gives better internal coating during downtimes, sitting in the garage but also clings to the metal parts so when I do a cold-start, my internals are protected not only against wear but corrosion!!
https://www.amsoil.com/p/amsoil-form...motor-oil-aff/ |
#10 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
IMO Changing weights within the range of 0w-40 and 15w-50 wont hurt so long you are sticking to full synthetic. See the chart below. I run a 5w-50 Supercar now, with my remote oil cooler, but ran the 0w-40 supercar before then.
