![]() Drives: Camaro ZL1 Join Date: Dec 2024
Inter cooler chiller pros and cons
I got a 2018 ZL1 making 1150rwhp and and I currently got and ice box and had it for a while but, I’ve been seeing and hearing about the inter cooler chiller and would like to know if it’s worth it, would like to know the pros and cons thanks
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
The only con is slightly reduced cabin AC performance. I loved my chiller.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
What chiller do you have? I have the FI Interchillers Stage 2. I've not installed it yet, but FI Interchillers insist that the cabin air will not be noticeable different. They also recommend removing the stock heat exchanger all together as it will just cause more installation difficulty as a bypass solenoid value will be needed for a chiller on/off switch concept.
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Moderator
Not needed on cars that run E85 in my opinion. I’m on heat exchangers and my best quarter mile run was when my IAT2 leaving the line was 151 degrees…
Interesting!!! My IAT's never get above 155° even on the hottest of hot days! My IAT's average around 130° to 140° during the regular average summer temperatures!!! I might rethink about installing this Stage 2 kit !
Moderator
The fascination on this forum with IAT/MAT is unwarranted (UNLESS you’re on pump gas, which then you need all the help you can get lol). E85 is literally magic for boosted LT engines. It pulls a ton of heat out of the combustion chamber and gives you an octane number that requires virtually no timing retard unless you have crazy high IAT/MAT. So unless you’re stuck on pump gas, I don’t think it’s worth the weight & complexity.
#7 |
I agree on 1/4 mile runs, but on the street the chiller was awesome. My MAT's were never over 120 degrees.
#8 | |
Moderator
