Old 12-02-2024, 02:56 PM   #1
7speed
Drives: 21 SS
LT2 or Msd with baby cam
Those with smaller cam only car or in the know. I already have LT2 would it be really any gain and worth the money to switch to 103 and MSD with BTR 220 cam only?
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 12-02-2024, 10:09 PM   #2
avchz
Drives: Chevrolet Camaro
LT2 best bang for your buck, MSD good all around. I'd go msd.
avchz is offline   Reply With Quote
Old 12-03-2024, 07:38 AM   #3
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
MSD shines the most up top with a 103 tb. If you not going to live in the upper bands a lot your better off porting the LT2 with a 95mm and enjoying it.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 12-03-2024, 09:17 AM   #4
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I always laugh a little when someone describes a .660 lift cam as a "baby" cam
IMO I've never felt the $/hp was ever worth it for MSD/TB combo for a NA combo that wasn't going balls to the wall. In addition to the cost, few are pleased with the under the hood aesthetics of the MSD as well. The 220 may be the entry level cam in the BTR lineup, but it can certainly huff enough to make gains on a MSD if you're looking for peak power. But there are better combos if your goal is NA max effort.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 12-04-2024, 01:15 PM   #5
7speed
Drives: 21 SS
Yeah, was just adding cam to pick up mph for highway pulls and the 5 trips I make to 1/4 drags a year. As expensive as it will be, I didn't want to do converter or switch to msd/103 because at that $$ added I should just boost.
Only other thing I'm considering since right there is headwork.
FBO, E85
11.1@123
Old 12-04-2024, 02:07 PM   #6
GreyGhost702
Well, I wouldn't go that far. I think you can pick up a MSD & 103 TB for around $2k from Tick. Getting into a FI setup is going to be 4x that and then some. Whole other can of worms lol.
Head porting is worth it, IMO. And regardless what you do with the car, the more you pile on the parts in the future the ported heads will help it shine.
Old 12-04-2024, 03:13 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It's all about the combination. MSD/103 combo would shine more with a BTR 230 cam where you are shifting around 7200rpm.
LT2/95 combo will work btter with a BTR 220 shifting around 6600rpm.
Old 12-05-2024, 09:57 AM   #8
Katech_Mike
Drives: 2015 Camaro ZL1
Mild head/cam LT1
Red: LT1/87mm
Blue: LT2/95mm with tapered adapter
Black: MSD/103mm
Green: Plazmaman Billet/103mm
Katech_Mike is offline   Reply With Quote
Old 12-05-2024, 01:23 PM   #9
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
MSD is really only beneficial over the LT2 past 6k RPM. Even then its just a few horsepower. If you already have the LT2 / 95mm TB, I don't see a point in upgrading unless you just need every last bit of top end power.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 03-26-2026, 09:25 AM   #10
Sheldor
Drives: 2017 Camaro SS 1LE
I want the lt2/lt5 combo. I bought all the parts from g p I and had to return them all because they would not send me the correct map extension, harness that would fit. One end would click in the other end would not. They also did not offer any sort of help. So i'm stuck with msd/katech103. I have the gpi ss3 cam kit, NA.
Sheldor is offline   Reply With Quote
