![]() Drives: Camaro ZL1 Join Date: Jul 2023
1000HP ZL1/1LE
2018 ZL1/1LE track package
23K miles on body 2200miles on build (Engine/Blower) 100 miles on trans/clutch Located in Amarillo TX 806-570-1378 I don't get on here much so please text/call if you are interested. Asking $72,000 Engine: 377ci CP pistons & Mahl Rods Callies Crank Frankenstein Cylinder Heads BTR custom cam Katech oil pump LME timing chain with billet tensioner LME billet timing cover ATI damper Super Charger: Magnuson 2650R TooHighPSI lid TooHighPSI port injection plates TooHighPSI valve covers TooHighPSI 10rib pulley kit with ZR1 tensioner Katech 103mm throttle body & Inlet RotoFab big Gulp MightMouse catch can CX 6 gallon ice tank 3” heat exchanger Smooth Boost controller Fuel System: Crawford Port-injection Holley dominator FIC 1000cc port injectors Triple pump kit 30% injectors with big bore pump Transmission: RPM performance level 7 Mantic Triple disc Clutch OEM slave cylinder Wheels/Tires ForgeLine XR 17x10 with beadlocks rear on a 305/45 ET’s Forgeline fronts 18x8 with toyo’s Exterior: Entire car is wrapped in PPF Anderson front splitter Anderson side mirrors Exhaust: Kooks headers Corsa cat-back |
2020 Shadow Gray 2SS
Honest question, I realize those are drag radials, but do 305's get 1,000 RWHP to the ground effectively? I was expecting to see at least 345's... But I'm way out of my wheelhouse, so I don't know...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
They do work very well for this vehicle. I’ve had 345’s on the car before when it had a F1A pro-charger setup and they did well but with more instant torque the Magnuson makes. I definitely needed more sidewall so that was the reason for the switch to 17’s and 305’s.
#4 | |
Moderator
I agree
#6 | |
I figured as much!
#7 |
Yessir your welcome
#8 |
![]() Drives: 2022 SS 1LE Join Date: Apr 2022
Hey GulfZL1, can you give me some details and/or pictures on how to install a MM catch can to your Magnuson? I have an SS with a Magnuson, but I don't see how I can install a MM "wild" catch can. I also can't find anything on youtube or on these forums.
Thanks |
#9 | |
jfkheat
Drives: 2023 ZL1, 2023 Challenger Hellcat Join Date: Nov 2023
#10 |
#11 | |
Moderator
#12 |
Thanks 99, I'll take some pics and get your opinion on which 1 is the vacuum. I think it's one behind the TB, on the snout of the Maggie.
#13 |
![]() ![]() ![]() ![]() Drives: CAMARO Join Date: Jan 2017
Any videos of the car? Sound clips?
Beautiful car |
