Old 11-27-2024, 04:23 PM   #1
GlennB12
GlennB12's Avatar
Drives: 2021 Camaro LT1
Squeak sound.. unsure what to do.
Hey everyone, I got a squeak noise that is only present when I first start rolling as well as when I hit the brakes at low speeds(0-15mph). Seems to go away after driving a bit and it just started out of no where.
Brake pads look good still and car only has 30k miles on it.
Should I be greasing something up ? I had someone tell me to grease my boots up? Thought I’d get y'alls opinion in case someone here has experience something similar, before I take it somewhere to get looked at.
I am also by myself so it’s hard to pin point the exact location of the squeak/squeal. All I can confirm is that it’s not coming from the engine area.
GlennB12 is offline   Reply With Quote
Old 11-27-2024, 04:35 PM   #2
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
I had something like that going on a few weeks ago. I parked, engaged and un-engaged the parking break. It went away and never heard it again. Don't ask me, IDK
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 11-29-2024, 05:18 AM   #3
Speak99
Speak99's Avatar
Drives: Camaro 2020 2SS VERT
I had a squeel sount coming from the rear on acceleration, turns out it was the baffles in the exhaust, there is an spn in this, someone here showed it to me. I ended up spraying tons of dry lube on them and it went away.
Speak99 is offline   Reply With Quote
