Old 11-23-2024, 04:10 PM   #1
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Belt slip issue...................
Had an issue with belt slip as you can see in the 2 screenshots posted. You can see the dip in the boost in the first picture. They don't make the green belts in the size I needed so I was using just the standard gates belt. I also tried the drayco belt but has the same issue. I noticed that there was more than 1/2 travel on the tensioner pulley. The next size down was too small so I had to find a belt the same size that didn't have as much play. This goodyear belt is nice and tight barely any travel in the tensioner now. Its been on there for about a 3 weeks so lets see how well it holds up.
Just another option for those if you can't get a greenbelt in your size. Side note this is a 6 rib setup with the factory box setup procharger.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 11-23-2024, 04:59 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
I just concluded that I can't use the 2.625 pulley because the belt was slipping even with a DSX idler bracket and I based that solely on lower absolute manifold pressure than that of my 2.75 pulley, not my any huge fluctuation in the MAP PID like yours. On the other hand, although mine has minor fluctuations in map, the RPM curve looks like corduroy. It's just a long series of up and down movements in RPMs all the way to the shift point, not good
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-23-2024, 05:26 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Better off going larger on the crank pulley rather than smaller on the blower pulley IMO.
Old 11-24-2024, 02:55 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
You're probably right buddy. For some reason I've been trying to hang on to this 9.17 that Hennessy put on there 4 and 1/2 years ago and it's outlived it's useful life so I'm going to put a larger bottom pulley on it like a 475 or something. Whatever gets me to 25,000 at 7, 000 with a 2.75 or 3-in upper
2020 ZL1LE A10.
Old 11-24-2024, 05:42 PM   #5
Joshinator99
Moderator
TooHighPSI sells two overdrive pulleys. I’m tempted to try out the 10.35” one (I’m on his 9.24” one now with 3.25” upper). If you still have a front sway bar you’ll need his “fit kit” too to space it away from the big pulley.
https://toohighpsi.com/products/copy...43548679700695
Old 11-24-2024, 05:50 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
At a quick glance, it looks like this one will work --- 245mm (9.65") [LSA 23%/LT4 20%] IDLER RELO BRACKET REQUIRED FOR LSA --- but I would only pickup 1000 rpm and better grip
2020 ZL1LE A10.
