Old 11-21-2024, 11:35 AM   #1
Colin101234
Colin101234's Avatar
Drives: 2017 FIFTY 2SS HCI
2nd gear burnouts ???
Can you guys do second gear burnouts in your 2ss w/ stock clutch?? The car has more than enough power to do 2nd and probably do a 3rd gear burnout, but the clutch just slips if I try to start it in second. It slips bad. So I'm wondering if any of you guys are able to do this on your stock clutch or if it's time to upgrade mine.
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639])
1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune.
Colin101234 is offline   Reply With Quote
Old 11-21-2024, 04:06 PM   #2
s346k
s346k's Avatar
Drives: like an old lady
i did 2nd gear burnouts at the track on drag radials and only on street tires on the street. did this for 35k miles, no issues.
Old 11-22-2024, 08:15 AM   #3
GreyGhost702
Drives: 2019 Camaro 1SS1LE
There's a difference lighting up your tires on dry pavement vs drag track with a burnout box. Dropping the clutch on dry pavement in 2nd if you have a setup that promotes any traction at all is brutal on the driveline. If your clutch is glazed, it takes a bit to "walk it off" and if the clutch material is damaged it's grip is going to be permanently degraded.
Try starting in 1st and then click 2nd. Use a little water to help get started.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 11-22-2024, 12:50 PM   #4
Classic Muscle
Drives: 22 SS 1LE
How is dropping the clutch on dry pavement in 2nd any harsher than doing it in 1st, and any worse than dropping the clutch and launching the car on a prepped surface at the drag strip?
Anyway I tried a quick hazing of the stock tires in 2nd at the drag strip after driving around the water box and it wasn't too hard. Just had to feather the clutch a little and roll on the gas. Seemed to be smoother and more controlled than doing it in 1st. Took me a couple tries though to get it down.
Classic Muscle is offline   Reply With Quote
Old 11-22-2024, 01:13 PM   #5
MyNameIs
Drives: Camaro SS
Sure I can do a 2nd gear rolling burn out.
MyNameIs is offline   Reply With Quote
Old 11-22-2024, 01:24 PM   #6
GreyGhost702
Because you have less gear advantage in 2nd than 1st. Dead hooking on a prepped drag strip is probably as harsh as it gets. Never said it was bad or good.
Old 11-25-2024, 10:24 AM   #7
Colin101234
I don't mean a rolling burnout, I mean starting in second from a stop.
