Old 11-15-2024, 07:47 PM   #1
winged1
Drives: 2016 2SS Auto
Turbo Kit LT1 SS
Looking for a turbo kit single or twin set up for my 2016 Camaro ss. Are there any good options besides Huron and hellion? Any recommendations are welcome. Thanks
winged1 is offline   Reply With Quote
Old 11-15-2024, 08:57 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Those are the two major, and pretty much only, choices. Outside of that you can custom build a setup and a couple of guys in this forum went that route.
Old 11-15-2024, 11:19 PM   #3
winged1
Yeah I’m looking at the hellion kit. I’m already at 515rwhp PRC heads and stage 1 cam 8spd. Looking for 650-700whp.
Old 11-16-2024, 08:08 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You will be adding a lot of complexity to the car by going twin turbo. A simple procharger or magnuson setup will hit those power goals very easily.
Old 11-16-2024, 08:27 AM   #5
Joshinator99
Moderator
100%
Old 11-16-2024, 09:38 AM   #6
winged1
I realize that and totally agree. There are pros and cons with either set up. I have had superchargers, Procharger’s, Vortech, PD, and currently the car is set up with nitrous. I want something different, more efficient, more room to grow, and just plain looks and sounds better. Everybody has a supercharger. Next year plan will be to upgrade the internals, lower compression and go for 900+hp. As it stands, with a 75 shot my 2013 rwd BMW M5 (4.4 twin turbo stage 2) will absolutely destroy my Camaro 0-60, 60-120 and after 130-140 there is absolutely no comparison. By the way I’m already running e85 with the Camaro. I’m not sure exact dyno #’s since it was dynod in 4th gear. I’m pretty sure I’ll be going with the hellion kit. I’ll be installing it by myself in my garage. It will take some time since I work 40-60hr/week. Thank you guys for the responses.
Old 11-18-2024, 03:42 PM   #7
Katech_Mike
Drives: 2015 Camaro ZL1
Huron Speed is a great company to work with. Highly recommended.
Katech_Mike is offline   Reply With Quote
Old 11-19-2024, 09:41 PM   #8
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
If you have interest in the Hellion Kit, you should check out the link below for the installation done by Jannetty Racing
https://www.facebook.com/jannettyrac...5676361319091/
GAOLDGUY is offline   Reply With Quote
Old 11-23-2024, 09:02 PM   #9
winged1
Just to update: I went with Huron TT kit. Also picked up a JMS voltage booster and zl1 lp in tank hat. In the end the Huron kit was easier to install and 3k cheaper. I’ll be installing everything in my garage.
Old 11-23-2024, 09:51 PM   #10
Joshinator99
Moderator
Nice! Post some progress pics and dyno results when you’re done.
Old 11-24-2024, 05:57 PM   #11
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Port injection should be high on the priority list, after that it will depend on the intended use. Are you just roll racing?
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 11-25-2024, 10:47 AM   #12
winged1
Just looking to have some fun with it. If I do race it will be from a roll. Going to max out my current fuel set up and see what it puts down. Next year I’ll go with gpi drop in pistons/rods then look at port injection. Of course I’ll up the boost at that point. For now 5-7psi will probably put me over 700whp.
Old 11-25-2024, 11:08 AM   #13
jlaudio11
jlaudio11's Avatar
The reason I'm saying port injection is to get it on E85 and keep those ringlands intact at that power level. Laynlo15 did a real simple build with a magnuson 2300, port injection and boost a pump, went 9's in the 1/4 and 700 something hp on a stock engine. I would suggest following it. I hurt my crank before I could lean on my stock fuel system like you are trying to do and just went port when I did my cam, crank, rods and pistons. Beyond those things a converter will have the biggest impact on the way the car performs, even roll racing. I ran the stock converter for quite awhile and it was fun and fast on no prep but a whole nother world with a looser converter.
'20 Camaro LT1
