View Poll Results: Best Brembo front brake pads
P10064 low metallic, more expensive, black backing 2 50.00%
P10064N ceramic, slightly cheaper, red backing 2 50.00%
Voters: 4. You may not vote on this poll
Old 11-15-2024, 10:34 AM   #1
blpadge2
Drives: 2016 Camaro Convertible 2SS
Yet another brake pad thread -- Brembo aftermarket pads
Background: 2016 2SS Convertible. Last inspection I was told I had 2mm pad left in the front and 5 mm in the rear.
I have never done a brake job in my life, except helping my dad when he did them (my first car 1975 Monza Town Coupe was one time). I want to try it thanks to YouTube rather than pay the dealer $$$ per axle.
For simplicity sake I think I want to stay with Brembo pads and just have the stock rotors turned vs. shelling out $450 to $550 for PowerStop Z26 pads and rotors.
So now my question. Brembo says the replacement pad for the front is P10064 low metallic or P10064N ceramic. The rear pads are P10071N ceramic. Which pad is better for the front, low metallic which is more expensive or ceramic which is cheaper?
I know rear brakes wear less than the fronts, so the fact that the rears only come in ceramic and are cheaper in ceramic for the front makes me think that the low metallic is the better, longer wearing pad. The low metallic has a black backing, and the ceramics have a red backing.
I'd rather buy the aftermarket Brembo genuine pads vs. going to the stealership for GM part number Brembos which are going to cost double or triple what an aftermarket Brembo pad costs.
Thanks for your response.
blpadge2 is offline   Reply With Quote
Old 11-18-2024, 06:24 AM   #2
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
If you are not going to track the car at all I would go with a good ceramic pad and call it a day. Lower dust and longer lasting rotors. Check out Rockauto.com for some of their pad options they have. Just my opinion
dmcmahan60 is offline   Reply With Quote
Old 11-18-2024, 07:39 AM   #3
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
I would just do ceramic unless you're racing the car.
Just take your time and stay organized doing the brakes for the first time. Plenty of info out there. Spend some time getting organized and gathering info. Good luck
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 11-18-2024, 11:50 AM   #4
ctrlz
I would get powerstop z26 pads off amazon.
Refacing the rotors or not is up to you. Getting them off the car can be a real pain sometimes.
Plenty of youtube tutorials on this.
If you are worried about your skills being rusty, you could always do one axle at a time with a test drive in between.
Really, if this is your first solo brake job, and the grooves in the rotors are 1-2 mm deep, I would just put on new ceramic pads. it is not perfect, and maybe you will get 30,000 miles out of the pads instead of 40,000. But you will get the satisfaction of doing it yourself without the hassle of pulling the rotors.
Old 11-21-2024, 02:21 PM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
These days in their seeking of less weight, better mileage, etc.. car makers are giving us thinner brake discs that don't tolerate "turning" very well.
If you are not experiencing any brake pulsating or any indication of a warped disc, I have found simply rotating the disc in place while holding a piece of 200 grit sandpaper to remove the old brake pad material (really necessary if changing pad material), off the front and back of the disc. Spray it down with some brake cleaner to get any dust off and swap the pads.
Ventmaster is offline   Reply With Quote
Old 01-09-2026, 11:51 AM   #6
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Is the P10071N the part number for a rear 4 piston Camaro ss brake pad? Looking to replace my ss 1le brakes and saw the brembo ceramics for the front but didn't see that brembo had anything for the rear on the ss's, just the zl1's.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
best brakes, brembo, cost, pads
