Old 11-09-2024, 05:49 PM   #1
Milesmonte
Drives: 2011 1 SS IMPERIAL BLUE
Oil Change & Differential Fluid
Hi, all I know this may have been discussed here before, but can not find it.
I have a 2023 1 SS with approximately 3,500!
I have changed the Oil Once @ 1,300 Miles is it necessary to change again @ 3,500 or should I wait?
Also what about the differential Fluid should that be changed also at this time with 3,500?
Thank you for your help and thoughts.
Milesmonte is offline   Reply With Quote
Old 11-09-2024, 06:05 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I would change both, fluids are cheap, components are not...
Old 11-09-2024, 07:02 PM   #3
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I have v6 manual, limited slip differential. I changed mine at about 35k mile intervals. Now has 73 k miles. Lt1 uses expensive oil I would change at %20-%30 on olm.
Gen6cyl is offline   Reply With Quote
Old 11-09-2024, 10:07 PM   #4
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
Changing the diff fluid wouldn't be a bad idea, after break-in it tends to be kind of murky. As for the oil, you barely have over 2,000 miles on it, so not really necessary, especially if you are using the full synthetic Mobil-1. The only exception would be if it's been over a year since the last change. For example, my standard interval is once yearly, because I drive maybe 1,500 miles a year at best, and so a typical 5,000 mile oil change would take several years to reach (not ideal obviously).
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is offline   Reply With Quote
Old 11-11-2024, 07:32 AM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
I agree with JT6 on the diff fluid. You should base your oil changes on how you drive the car, when, where, etc. Such as if you track your car or just a Daily Driver. if it's your DD and you have already changed for break in, just get on the 5k mile change routine and should be good.
hrpiii is online now   Reply With Quote
Old 11-11-2024, 02:54 PM   #6
Milesmonte
Thank you RPI III That's exactly what I did this this morning.
Had the Dealership change out the Differential and had off on the second Oil Change.
