Go Back   CAMARO6 > Marketplace > Members Classifieds > Suspension / Chassis / Brakes
Old 11-08-2024, 10:13 AM   #1
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
F/s Silvers neo max 2way coilover
I have a incomplete set of 2 way coilovers with next to no mileage on them.
You will need to buy springs, perches and top hats from silvers.
I have the bump stop and dust cover for the fronts that are not in the picture
These retail at $2100
I will take $900 for these since it will require a bit of leg work.
Compression and rebound both adjustable and they use much thicker oils for 2 ways then 1 way coilovers that doesnt break down when hot during track use.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 11-14-2024, 02:39 PM   #2
shogun37
Drives: none
no miles since last rebuild? AR15 wrench aside, do you have the specs on oil used or tools to service? there isn't a hose joining the reservoirs to the main bodies? Is the compression a high-speed or low-speed adjuster?
what settings did you settle on?
shogun37 is offline   Reply With Quote
Old 11-14-2024, 03:01 PM   #3
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
definitely need the bracket clamps for those front rezzies
FactoryMatt is offline   Reply With Quote
Old 11-18-2024, 07:12 PM   #4
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
You would need a clamp for the reservoirs not a hose, the fluid goes thru the hard mount holding them. they were never rebuilt. They have about 100 miles on them.
Lmao the ar15 wrench and lube yes
My settings vary on track condition and what tire im running.
