![]() Drives: camaro ss Join Date: Jun 2018
Had an issue the other day while running a quick errand. I tried to start my car but the starter kept turning over but wouldnt start. I have this issue before but it would eventually start after 4-5 cranks. I noticed after trying once or twice there was a plasticky burning smell under the hood.
Eventually I had someone help jump the car which helped me get home but the next day I had a check engine light (which just disappeared). Do you guys think its a faulty starter issue and I should get it checked? Or not worry about it since the signals went away and the car has been starting normally otherwise. The temp was in the 60s/70s that day so I don't think it was heatsoak or anything. Its a 2017 Camaro SS just for reference. |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
It can very easily heatsoak in those temperatures. If you’ve been having this issue for awhile and failed to address it you’ve probably damaged the starter solenoid at this point.
You should replace the starter and then add a thicker gauge ground wire. Search these forums for how to do the last part.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#3 | |
My 2017 2SS still starts on the first crank every time. Three seconds of cranking at most. I did replace the battery at the 5-year point. But no changes to starter wiring/block grounding as others have done. |
Any videos on how to install additional ground wiring?
![]() Drives: '23 2SS VOM Coupe Join Date: Nov 2021
This thread has a lot of discussion on the topic:
https://www.camaro6.com/forums/showthread.php?t=586153 I did what 2SS Capt did (from the above thread): https://www.camaro6.com/forums/showp...&postcount=212
2023 Vivid Orange Metallic 2SS Coupe
A10, NPP, MRC, BCD Brakes, Black Forged Wheels, Black Lugs, Alloy Pedals, 40% Llumar Stratos Tint, Adam's Ceramic Coating Range AFM Disabler, Kanguru 3D Spidermax floor/trunk mats, DIY NPP Switch Vivid Orange '23 2SS Coupe 1100: 4/19/23 3000: 5/8/23 (TPW 5/27) 3800: 5/31/23 5000: 6/9/23 6000: 6/16/23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Someone mentioned the battery. I would get that tested if it's more than three or four years old.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD Last edited by GroundhogSS; 11-07-2024 at 05:21 PM. |
#7 |
![]() Drives: 2017 Chevy Camaro 1SS Join Date: Oct 2019
Bump, but Can confirm I’m having that slow crank issue with the hot start, but also getting that strong smell after it finally cranks, the battery was replaced 4 months ago, went to the auto shop to check if it was faulty but they said that the battery was healthy but needed charging.
2017 Camaro SS |
#8 | |
#9 |
but what’s the smell coming from? it almost smells like either a plastic or electrical smell…
#10 |
Starter solenoid.
#11 |
If the solenoid is the source of the smell then it is either overheating or arcing across the contacts. Both situations point to a problem with the solenoid, which is integral to the starter assembly.
I know some will want to say "bad ground," but bad ground would cause an undercurrent situation. |
#12 |
Should I replace the starter then?
#13 |
#14 |
![]() Drives: 2016 Camaro SS / 1SS Join Date: Nov 2016
I've been fighting this heat soak issue for the past year now.. I had one time where I had to wait about 35 mins before being able to restart. I just ordered a grounding cable (24"). What is the best / easiest connection point on the engine to use for the additional grounding cable? The negative post on the frame is easy and makes sense, but the tensioner bolt seems to not be too easy to use. I did see the option of just loosening the tensioner bolt and then cutting the ring terminal to make it a blade type so you can slide it under the bolt without removing. Is this the easiest method or is there another more convenient bolt to use on the engine? Thanks for any advice. Hard for me to fathom how GM did not correct this issue which was / is present on the 5th gen Camaro's as well.
| Tags |
| burning smell, starter |
