Old 11-01-2024, 09:44 AM   #1
rarest_spun_heaven_metal
rarest_spun_heaven_metal's Avatar
Drives: 2020 V6 Camaro Vert
Broken top with no end in sight. Considering manual hydraulic release...
Hey y'all,
Proud owner of a 2020 V6 convertible here. I'm at about 58k thousand miles. Unfortunately, back in July 2023, when I was putting the top down one sunny afternoon, it stopped halfway. I was unable to get it to go any further, there was no apparent blockage. I was able to put it all the way back up, but I have not been able to put the top down since then.
I took it to the dealer in August, and they determined that I had a faulty sensor and that they would need to replace the whole top. When the replacement top arrived, it was faulty (apparently, it was some sort of return), and so they needed to request another top, but it's currently on backorder with GM. It's part number 85636529, for reference.
So it's November 1 now, and my top has been not functioning since the summer. I'm starting to feel like maybe the convertible days for my camaro have come to a close (we had a good run. 4 years, 50k miles). Any advice on how to navigate or workaround the backorder with GM would be appreciated.
Also, I'm getting frustrated about not being able to experience the fall foliage in all its glory, and I read online that there's a manual release of the hydraulic system for the top that I might be able to utilize to the top down manually. Does anyone have any experience doing this? Or know where this is located?
Or is this generally a bad idea?
rarest_spun_heaven_metal is offline   Reply With Quote
Old 11-01-2024, 01:58 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The instructions for manual top operation are given in the Camaro Owner Manual. You can download a copy from the Chevrolet web site if you don’t have a copy. The instructions seem to be for getting the top back up if it’s stuck. They don’t seem to give you a way to put the top down manually.
Old 11-01-2024, 02:17 PM   #3
beowulf556
Drives: Camaro SS 1LE M6
A faulty sensor = a whole new top? That's crazy!
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
