Old 10-28-2024, 09:08 PM   #1
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
How do you remove a frog from a gas tank?
So this happened.... My wife Ildi went to fill up her Pathfinder and upon removing the gas cap... a frog was staring at her. She tried to get it out but he was already half way inside the filler neck and the opening. How he got there... I do not know. Long story short... she had someone try and help her to remove it and the frog decided to slide his way into the gas tank. I removed the wheel and wheel liner... I do not see any exposed openings to where or how the frog would've gotten behind the gas filler neck and still be alive and alert to make eye contact with my wife. Make it make sense.... Pics below...
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 11-21-2024, 09:46 AM   #2
Trickskier
Native Floridian
Trickskier's Avatar
How the heck did it get in there?
Old 11-21-2024, 02:07 PM   #3
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I thought it was going to be a joke when i read the title lol. Sadly may ways to remove it but will probably kill the poor frog. Maybe a bent coat hanger and try and gently pull it out
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 11-21-2024, 05:17 PM   #4
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Well if the frog dies in the extraction process at least he'll die high as a kite on gas fumes.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 11-21-2024, 07:07 PM   #5
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Vacuum?
0stones0 is offline   Reply With Quote
Old 11-21-2024, 07:19 PM   #6
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
My guess is it was some sort of prank on whoever went to get gas Maybe it was thought the frog would jump out or something...Halloween....teenagers....or kids goofing around.
(Who hasn't put airplane glue on a frog and lit it off when you were a kid??...lol)
Anyway, I'd investigate to see whos snickering about it...lol...good luck!
Old 11-22-2024, 06:30 AM   #7
Trickskier
Native Floridian
Trickskier's Avatar
Originally Posted by 0stones0 View Post
Vacuum?
NO!!! I know a guy who tried to vacuum gas out of a boat. Once the vapors hit the sparks on the vacuum motor it exploded!!! He was blown out of the boat and burned extremely bad!!!
Old 11-22-2024, 06:40 AM   #8
Trickskier
Native Floridian
Trickskier's Avatar
If you can still see the frog. This tool might work. You can buy it at Lowes.
Old 11-22-2024, 06:57 AM   #9
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Get him to eat a bolt then use a magnetic pick up tool. J/K
Force him down he will dissolve...he is as good as dead from the fumes now anyway.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 11-22-2024, 06:44 PM   #10
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
I'm sure that you will have to drill out some ribbits.....
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 11-23-2024, 06:00 PM   #11
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
A match and a catchers mitt?
SwL_Wildcat is offline   Reply With Quote
Old 11-23-2024, 06:05 PM   #12
0stones0
It don’t come easy.
0stones0's Avatar
Ever suck gas out of a tank with a hose?...might get a little frog flavor but...
Old 11-24-2024, 01:39 PM   #13
NjaTrtl
NjaTrtl's Avatar
Drives: '22 2SS 1LE M6, '12 Audi Q5
Poor little guy's Frog Soup now. :(
1st - '65 Ford Mustang - Candy Apple Red
2nd - '77 Pontiac Trans Am - Black/Gold
3rd - '79 Pontiac Trans Am - White/Gold
4th - '86 Chevrolet Camaro IROC Z28 - White
5th - '91 Ford Mustang GT M5 convertible - White
6th - '00 Chevrolet Camaro Z28 M6 - Rally Red
7th - '12 MINI Cooper S M6 - Chili Red
Last - '22 Chevrolet Camaro 2SS 1LE M6 - Rapid Blue
NjaTrtl is offline   Reply With Quote
Old 11-24-2024, 05:47 PM   #14
Whoomba
How did it get in there in the first place?
