![]() Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
AWE to Corsa Compatibility
Hi all,
I might pull the trigger on the Corsa variable valve system (just the mufflers) soon but I was wondering if there would be an issue connecting it to my current system. I have the AWE Track Edition x-pipe and axle back system Thanks |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
Are you replacing just the axleback section of your catback setup? There should be no fitment issues as long as its cut in the right place. AWE pipes run basically same path as stock. Any work to correct fitment issues should be pretty minimal, if any at all.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
#3 | |
Not AWE but I bolted Corsa NPP mufflers to a Borla X pipe with no issue. I will warn you that Corsa has problems with the valves rattling. They now provide service kits for the valves. Basically, the valve shaft develops end play over a short time and will rattle when closed.
#5 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
Agree...Stock, Flowmaster, Corsa. All ended up doing it. The good thing about Corsa is their warranty and CS is pretty good. They now send out service kits for the gen 2 valve systems, but my mufflers have the gen 1 valves that are not serviceable which means the mufflers need replaced. Anybody buying the current NPP now gets the gen 2 valves. The service kit is basically a bolt and spring washer that keeps tension on the end of the valve shaft, so it doesn't rattle.
#7 | |
https://youtu.be/FAa0Y4JJcTc?si=wbLOdd96MeVu_V7J
#8 |
I guess the springs aren’t a huge issue if Corsa sends the kit but it is an inconvenience. I like the idea of having the valves and being able to control the volume when you start up but I was looking at the Corsa extreme system as well. Is there a big difference between the valve version and the extreme in terms of sound?
#9 | |
If you are staying stock headers and cats, the Extreme would be ok. But if you plan on headers and/or catless down the road it will be way too loud. Either way I don't think you will ever find a perfect valved exhaust. You are going to get a rattle/rasp over time with any of them just like stock. I have tried 3 different NPP axle backs. The Corsa is the best that I have experienced, but it still suffers the same fate. If you want to try the Corsa NPP, I'll sell you mine I took off for cheap. I have it listed in the FS section with pics. It's boxed up in the factory box with foam.
#10 | |
#11 |
You could easily order black tips for it and still save a shit load of money on an overpriced exhaust. jmo
#12 |
#13 |
I am having fitment issues. I just picked up my system this past weekend and tried installing it but it won’t fit. My AWE X-pipe has a 3” OD and a 2 7/8 ID. The Corsa has a 2 7/8 OD and a 2 3/4 ID. I don’t think an adapter will work, right?
