![]() Drives: 2016 SS Nightfall Gray Join Date: Oct 2016
Steady hi voltage - 14.5. Alternator?
A few days ago I started hearing an occasional squeak. It sounded like a pulley bearing, so I planned to find what it is this weekend.
But today, I noticed my dash volt meter stayed at a constant 14.5v, regardless of speed or load. I figure it’s the alternator, but looking for input. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Personally I think you either have a bad belt or another pulley has bearings going out. I don't think I've ever heard an alternator squeak.. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
for a 16 test your battery and alternator, I assume both are OE and if so are 8 years old now. If it's charging in an acceptable manner it won't as you noticed be pegged out at 14.5v constantly.
The voltage reading will vary from 10.5 to 14.5, but it may take a bit of driving until you see it move.
The alternator output is controlled by a single wire directly from the ECM, which alters the duty cycle. this is a relatively simple part of the larger "power management system." |
#6 | |
#7 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
I would test your battery first, it's the easiest. A legit load test. If that checks out, it'll suck but the alternator would be the next to test. Even with passed tests, I've still had alternators that were funky and would pass. For $250 I'd throw a new one in if the old one comes out. Don't core it right away, just in case you find there was a shitty ground somewhere or frayed wire, in the event it's still pegged.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#8 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
#9 |
L8ap3x
Just a comment on the voltage part.
One of these photos is what a normal battery looks like throughout the day when you start and drive the car. The other photo is what your battery does when it's plugged into a tender and going through the first initial phase of desulfurization. As you can see, fluctuations above 14 are very very common.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
#10 |
L8ap3x
You can buy this little battery analyzing device on Amazon for a few bucks. Here is a 7 -day synopsis of what my battery does. You can see the days I drive it. The days I don't. And the days that it just sits and charges.
This is a very good way to monitor your battery long-term throughout months or years to establish patterns or indications of when it's beginning to fail. I actually have this device on both my Trailblazer and my Camaro. $30 https://a.co/d/hoQTyAv
#11 |
Very cool. This will be perfect for a Honda cr-v I just inherited. These have very high standby drain (according to the forums) plus the stop/start kills the battery. My aunt used this as the proverbial grocery getter and the 3 year old battery was toast from the stop/start
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
went though this on my 5th gen.had battery and alternator tested at multiple shops after my car suddenly didnt start one morning.jumped it off and it was fine.the system is either not charging and reads 12.5 or <14.7 when charging..i lubricated the hinges after noticing the interior light stayed on for longer than they should have and its still running fine over a year later.conclusion...these new cars are much different from the old iron.if it aint broke dont fix it,just keep a a watchful eye.do you drive long enough distances to charge enough where charging voltage drops?
#13 |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Belt tensioner pulley.
#14 |
![]() Drives: Chevy camaro SS 1LE Join Date: Aug 2024
Hopefully not the alternator. Real PITA to change.
