Old 10-03-2024, 01:59 PM   #1
Wildcard
Drives: 69 Chevelle SS & 22 Camaro SS 1LE
Flood Damage Carpets - HELENE
Any techniques or tips on how to fix/SAVE flooded carpet, water damaged carpet?
My 2022 SS was hit with 2 feet of brackish water. Interior was NOT flooded, but a somewhere (it seems like the Seat Bolts) slight amounts of water leaked in and SOAKED the carpets. They did not have water levels on top of them.
I have wet/dry vacuumed the carpets to pull most water out. And have twice hit carpets with carpet cleaner, upholstery attachment. And have got from smelling like a Sewer, to now sweaty socks.
Wildcard is offline   Reply With Quote
Old 10-03-2024, 03:48 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
If water got inside the car, take everything out. Seats, carpet, etc and get it all washed and dry as soon as possible.
All the carpet padding has to come out - basically down to hard surfaces.
Might need water/bleach combo to kill any mold. That needs to happen ASAP!
ing for grip.
http://www.motorsportsne.com/
Old 10-03-2024, 04:27 PM   #3
FarmerFran
FarmerFran's Avatar
Stick the car in a giant bag of rice.
Seriously, sorry to hear this, persoanlly i would get professional help
<Insert Cars You Own Here>
Old 10-03-2024, 07:33 PM   #4
CHASLT1
Drives: 2021 Camaro LT1
I got 6" in my Vette so it is done and gonna towed out of the garage by the Ins soon.
CHASLT1 is offline   Reply With Quote
Old 10-03-2024, 07:45 PM   #5
Take it to a pro detailer that has a steam machine, an ozone machine and various vacuums. You want to prevent mold and bacteria from spreading in your interior as much as possible.
Old 10-03-2024, 08:30 PM   #6
Devstrike
Devstrike's Avatar
Drives: 2020 Camaro LT1
As others have said take it to a professional don't wait around for it to spread. Start taking out floormats now.
Devstrike is offline   Reply With Quote
Old 10-03-2024, 08:38 PM   #7
AZIROC
Drives: '86 IROC-Z '18 ZL1
Idk the cost difference, but id see what a replacement carpet would be vs detailing.
Old 10-03-2024, 09:34 PM   #8
Camfab
Drives: ‘23 ZL1-1LE
I’m going to say it didn’t come in from the seat belt bolts. The car was likely in deep water and that brackish water got past the door seals. Shampooing and vacuuming is like waxing the hood on a car that got into a front end collision, lol. I’m sorry it happened, but what you do now vs later can be the difference between a generally perfect car and one that’s forever water damaged. First off, hopefully you’re ok and this is the worst of your damage.
The best that you can do is to immediately pull out your seats, center console, sills, and assorted panels. Get those carpets and soaked insulation out. No amount of professional suction will work here. Understand that any moisture inside the car will wreak havoc on the interior, all electronics, etc.
My truck carpets, headliner got soaked because Chevrolet can’t seem to design a third brake light assembly that doesn’t leak. I noticed it driving to work, I left work early and gutted the interior in two hours. You’d be surprised that there are wiring harness assemblies that run under the carpet.
Good luck!
Camfab is online now   Reply With Quote
Old 10-04-2024, 07:43 AM   #9
ctrlz
This was my first thought. Those seat bolts usually have so much threadlocker on them.
Having been through a seawater flood on Sanibel, it is quite amazing how infiltrative and persistent the fine silt can be. Needless to say other crap comes with that. I agree the fix is probably to remove everything and do a deep clean or replace.
Old 10-04-2024, 10:07 AM   #10
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
Good luck!
Agree with CamFab... My mustang had a window/roof seal leak that put a lot of water into the carpet, we didn't catch it for a while so it got real stinky. We removed seats, console, carpet and jute. We cleaned the carpet with a commercial cleaning solution, then pressure washed it clean. Replaced all the jute because there was no cleaning that. There were a couple spots on the floor that bubbled the paint, so we cleaned and repainted that. Unplug any harnesses whose connectors might have been in water, and clean and grease the connections, then reassemble. hat was a few years ago, no problems since. The longer you wait, the harder you'll work to clean it.
In your case, you need to look at the bottom of the car too. Wiring, frame nooks and crannies between panels. I'd get some fluid film and spray that into any areas that are hidden interior channels. The fluid film will displace water and help seal up any open metal in there. Clean any accumulated dirt where the fenders meet the chassis, and other areas. Dirt will eventually destroy the paint that keeps oxidation at bay.
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
