![]() Drives: 2018 SS / 2021 ZL1 Join Date: Jul 2020
Rear end locking?
Hi everyone. I have a 2018 SS. Rear end had some rubbing noises and dealer flushed and changed fluid.
Improved some but now tire is wearing quick on right rear and squealing once in a while on right turns. Took it in, they replaced one link they said was loose but no improvement. Any ideas? Will take it back in but really want this fixed before I put new tires on again. No grinding sounds? Just tight and needs constant fluid changes? Only has 20k miles on it. |
#2 | |
Moderator
If that was your first time changing the diff fluid then that fluid was pretty cruddy I’d guess. I’d probably change that fluid again. They have to use a fluid with a friction modifier which the OEM fluid has. I’ve been using Red Line synthetic 75W-90 for years in mine for what it’s worth. But the differential should not be locking up like that.
#3 | |
I am going to say if it keeps needing the diff fluid changed then there is a possibility the differential is on it way out. I bought my car used with 11,000 miles on it and every time I changed the fluid there was more and more metal particles in it and black as tar
I beat on it a few times at the drag strip so it was my fault also that it eventually failed. One day it popped making a right hand turn and from that point on when you let off the throttle the gear whining was horrendous:( Don't want to freak you out but that is what happened to me.
Agree with all mentioned above. These diffs are very sensitive to the type of fluid used. I could only get mine to stop making a "groaning" noise on turns with GM fluid and adding the posi additive. Even at that when it gets below 50 degrees out it still makes a slight noise on the first couple turns then it's dead silent. I consider this to be "Normal" for these rear ends based on research and some performance shops I have talked too.
So I would try changing it yourself with GM fluid / additive first(it's super easy), and if it doesn't get better, you will likely need to replace the diff.
#6 | |
#7 | |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#8 |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Just did mine the other night, less than 10,000. Fluid clear, no metal on either plug. Drove it at 20 degrees outside. No noise, used GM OEM fluid.
