Old 09-28-2024, 12:14 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
A10 Clutches Slipping?
The car felt really odd this morning. It felt like it wasn't getting to the shift points as quickly as in the past. What PID do I look at to determine if the clutches are slipping?
This is my first A10. It's actually my first transmission where I was wondering about slipping clutches.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 09-28-2024, 01:23 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Log the last completed shift time.
Old 09-28-2024, 06:42 PM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
Jason is already logging that one; the time is like 0.1-0.2s, so I added time of the latest 4-5 shift. He is not seeing any slipping so perhaps I'm just paranoid but something's not right at wot.
2020 ZL1LE A10.
Old 09-28-2024, 07:04 PM   #4
Joshinator99
Moderator
Jason knows these things LOL…if he says you’re fine, you most likely are. 0.1-0.2 is perfectly fine. I was averaging around .18-.20 seconds at low to mid boost… then when I turned up the boost to about 85-90% that 4-5 shift went to 0.6 seconds…not good. I then tried full boost and the 4-5 shift went to a whopping *1.6 seconds* on what would have been a new personal best run….and then I pulled the transmission out lol…
Old 09-29-2024, 02:57 AM   #5
ZL14ever
Drives: 2018 Camaro ZL1 A10
Trans oil probably needed to get to operating temp. I know when the trans temp sensor in my C7 8l90e started acting up, converter lock up felt abnormal
ZL14ever is offline   Reply With Quote
Old 09-29-2024, 12:21 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
There's a distinct vibration today in 4th between 6000 and 7000. The only change from, say, two weeks ago when this wasn't happening is going down to the 2.75 pulley, so I'm going to replace the belt. It also does it with TC on. I've swapped upper pullies a bunch of times using this belt. At least we'll eliminate a variable.
2020 ZL1LE A10.
Old 09-30-2024, 09:21 AM   #7
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I'm not sure how it is in your area but weather is changing here with colder mornings lately. Colder temps can make the trans take longer to heat up, throwing off shifting a little bit. They can also have an affect on the engines characteristics and thus the indicated torque its making and what the trans uses to apply clutches, converter etc.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 10-02-2024, 09:38 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
I'm sending it to Pure.
2020 ZL1LE A10.
Old 10-03-2024, 09:42 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Good call...you are at the power level of when not if it fails.
Old 10-03-2024, 02:38 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
I agree. It's driveable but very unhappy in 4th at wot. It vibrates from 5000-7000 and the red shift light flashes [which also sounds like a slipping belt]. Jason looked at the data in every possible way, and we agree that there are probably clutches giving out and even if they're not, it's inevitable that they give out, so might as well just do it on my schedule.
2020 ZL1LE A10.
Old 10-10-2024, 07:34 PM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
My shop drove the car and put it on the lift and found the driveshaft rubbing the tunnel plus he says the backseat delete makes it sound worse. He doesn't believe its the transmission. So, do I send it to Pure or not?
2020 ZL1LE A10.
Old 10-10-2024, 08:16 PM   #12
Joshinator99
Moderator
How is the driveshaft rubbing the tunnel…? Are you still running the OEM driveshaft?
Agree with your shop 100% about the backseat delete…made the car so much louder.
If your shift times are still good then you probably don’t need to build the transmission…yet lol
Old 10-10-2024, 10:33 PM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
Yes. You?
2020 ZL1LE A10.
Old 10-11-2024, 06:51 AM   #14
Joshinator99
Moderator
Yes. You?
No lol… I’m on a GForce aluminum one piece. The OEM SS driveshaft is weaker than the ZL1 DS so I snapped it a while ago.
If you’re on the OEM DS I’m just wondering how it could be rubbing in the tunnel, unless the rubber mounts are cooked.
