![]() Drives: 2017 FIFTY 2SS HCI Join Date: Feb 2022
After i did a heads, cam, fbo setup on my 6th gen camaro ss the fan immedietly kicks on low and then a few seconds later ramps up to full blast even on cold start. AC is off. Ive tried switching the relay, unplugging everything plugging it back in, disconnecting the battery nothing seems to fix it. I know its not tune related because it started doing it even before it was tuned. (I ran the car after I finished the job at idle just to make sure all was well.) I am running a katech 174 thermostat but that was tuned in with hp tuners. Also it does it immediately way before the thermostat even opens. Any suggestions would be greatly appreciated!!!
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639]) 1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune. |
Petro-sexual
Any DLCs?
No CEL. But I figured it out, turns out the condenser pressure sensor wasn't fully connected.
#4 | |
Moderator
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Good to know what this does!
| Tags |
| cooling, fan, help needed, thermostat, tstat |
