old school chevy rodder
installing LPE voltage booster on 2650, also selling old 1740
SO adding the 2650 and eventually the dsx lid and the big gulp and 103 with additional tune I have ; I am adding a LPE voltage booster which appears to be a superior product to some others voltage booster, and of course costs more...
My question is anyone have installed one? I am wondering where to attach the hose from the actuator as the example in the instructions is a 2300 or some other magnuson and has a vacuum fitting on the passenger left bank toward the back..the 2650 does not have... I am installing speed valve covers changing that also....just BTW But wonder ...they show a couple "T's" in the pic of the kit but no mention in the online instructions..... And that may be what is needed from the vacuum line coming off? What..... its called a reference hose and the reference fitting.... which makes me think you could hook a gauge up there.... its step 54 on the instructions which seem pretty straight forward until it comes to this.. SO anyone have this bit of info it would be great, and on a side note I will sell the old TVS stock eaton off my lt4, mine is a bolt on build and a daily, so what i take off is for sale when its done in a couple months hopefully as I await in a que for help... It will include the lt4 lower pulley and belt and well valve covers etc etc.. so I will post that some day. And could use someone whos done the LPE on a 2650 to chime in, THANK YOU for your time... Mark
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Isn't the LPE booster just a rebranded JMS? If so, ditch the boost reference and use the pedal. Lots of threads about installing it that way on the forum.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
Moderator
Also if you’re installing the Speed Engineering valve covers…don’t. The PCV baffling is inferior to OEM and you’ll fill your catch can with oil very quickly. If you’re insistent on aftermarket valve covers, TooHighPSI ones are the way to go since the oil control baffling is to OEM spec (if not better).
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
LPE is the JMS with an LPE sticker on it.
Going 2650 and no headers?
GM Gen V Calibrator
wow no help here... Sorry I wrote anything.... no DIP switches to activate except theirs. I am not doing headers just shorty JBA incase in the future i want to go into the engine. I am going bolt on, and sorry if the speed engineering ones made with magnuson developing the 2650 are not so great..... I will find out with my e2x ultra. Having read thoroughly the instructions and such on both pumps they are not the same. And reading the posts online from camaro 6...... https://www.lingenfelter.com/PDFdown...all%20v1.4.pdf good luck to you all...........
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Thanks for stopping by!
#7 |
He brought it unto himself by saying this was a "superior product to some others voltage booster" in his very first sentence.
#8 |
#9 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I would recommend the GM pedal activated voltage version of the JMS. Boost is like a flat curve on the PD blower cars and it allows it to ramp up only as much as needed instead of just going flat out when boost hits.
#10 | |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
https://www.camaro6.com/forums/showthread.php?t=611982
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
#11 | |
#12 | |
Moderator
#13 |
hehe... just +1'ing your post bro !!!
#14 | |
fo'shizZL1
To the OP, we're just trying to give you honest advice based on what we know works, with countless examples, to prevent headaches before you install this stuff and can still possibly go another route if you decide to follow our advice. Also, if you do install this per the Lingenfelter instructions and use the boost reference instead of the pedal activation, PLEASE do not wire it the way they wired it in their instructions. Follow one of the many threads here instead, and put it in the driver's side of the trunk, and tap into the large wire going directly into the FPCM, and NOT the small gauge wires going to the fuse box as shown in the Lingenfelter instructions. EDIT: here's the one you want, in my opinion: https://jmschip.com/product/fuelmax-p2000gmp2/ it's possible you could just add the pedal harness if the base electronic unit is the same, too.
