Old 09-18-2024, 12:50 PM   #1
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
HOOSIER TRACK ATTACK PRO TIRES
anybody else seen these yet? look pretty good! but $500 a tire for 200tw tire is wild lol
https://www.tirerack.com/tires/hoosi...26c3e21c21649c
Old 09-18-2024, 01:26 PM   #2
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Same price as Yok A052 almost exactly.
That said RE71RS in 295/35/18 work great for less $ and last longer than Yoks. They also just came out with 305/30/19.
We'll see how the Hoosiers do, but beating the REs and A052s is going to be tough. They are really good tires.
Old 09-18-2024, 01:36 PM   #3
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Those look sick, but the price... wow. Crazy.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 09-18-2024, 01:53 PM   #4
It's all relative, these are still cheaper than my 315 wide PS4S rears...
Old 09-18-2024, 01:54 PM   #5
...and won't you look at that, the doyen of tire reviews just tested them and posted earlier today:
Old 09-18-2024, 03:07 PM   #6
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I've tried a lot of 200TW tires to include A052, NankangCRSV2, RE71RS, and our 220TW GYSC tires.
The CRSV2's are the fastest(on race tracks, not sure about autocross), very similar if not identical to Hoosier R7's around CMP. Both 315/30/18. These hoosier tires look slower than their R7 so I wouldn't bother personally. Will need to see where the dust settles once real people get these tires.
If that review above is accurate and these tires are half a second slower than the R7's I can guarantee you they won't be worth it, Nankang is still going to be better.
Christian1LE is offline   Reply With Quote
Old 09-18-2024, 03:43 PM   #7
DaveC113
DaveC113's Avatar
They are all (minus the SC3) within the noise depending on what car, track and weather they are used in. SC3 have much higher heat tolerance, so could be faster on a really hot day after a few laps.
Hoosier is saying they'll be faster than the competition, might be true in some cases and not others. Judging from the vid it's more an endurance tire than a TT/AX tire though, if so not really comparable to RE or A052. CRS is kinda in between, they seem to have a broad application but don't warm up fast enough on lighter cars. I wanted to try them in 335/18 square this year but they were sold out. A couple really fast drivers here have liked them.
Old 09-18-2024, 04:06 PM   #8
Christian1LE
CRSV2's are clearly better than A052's for me, I've used them back to back (with A052's being new and V2's being a few heat cycles in). For TT I will never buy A052's again. They are slower and it's not really within noise. Around mid ohio the 52's were clearly about .4 seconds slower per lap vs the CRSV2's. I used them back to back in 4 sessions.
Without a lap timer you wouldn't be able to tell but with my Aim2solo it's very clear. Pretty much every couple of corners I gain an extra red light on my timer.
Never tested RE71RS vs CRSV2's back to back so I can't comment on that. I bought the RE71RS once for rain but never really gave them an all out TT effort.
Old 09-18-2024, 04:25 PM   #9
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
How are the sidewall stiffness of the CR-S v2 compared to the GY SC3?
I am getting the CRS-v2 for my 718 GT4 in a few weeks, and previously had the SC3's (but are vaporware in my stock sizes for 2 years now) and now am on AD09's (because they also have stiff sidewalls).
To date the best tire I have had on my car was the SC3 with the AD09's a close second. Both the OEM Cup 2's and Dunlop Maxx Sport Race II sucked IMO.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 09-18-2024, 05:25 PM   #10
Christian1LE
I guess it depends on how tall of a sidewall you are getting. I have them in 315/30/18 and I feel the sidewall is fairly stiff. I've always ran lower profile tires though so I've never felt like tire sidewalls have really ever been an issue for me. I've ran taller take off pirelli slick tires before and they have a tall softer sidewall but it honestly didn't make a big difference either. All that is to say that I don't think I'm particularly sensitive to soft sidewalls, so I am probably not the right person to ask. But to me I don't feel like the sidewalls of the Nankangs feel any worse or better than the SC3.
When driving different tires the largest noticeable difference is in lateral grip between tires and how well they hold up to heat. It's very noticeable how early you can get on throttle with some tires vs others. Slower tires will give front end push way easier than the faster tires.
Old 09-18-2024, 05:50 PM   #11
TRZ06
TRZ06's Avatar
Gotcha,
GT4 OEM tire size is 245/35/20 F and 295/30/20 R
I notice small changes on my car because is has very little rubber bushings in the whole chassis system, so small changes have a large impact. More so than any other sports car I have ever had.
Good to know though that the CR-S's are at least a stiff sidewall constructed tire.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 09-18-2024, 07:11 PM   #12
DaveC113
DaveC113's Avatar
Brand new tires are usually significantly slower than tires a few heat cycles in.
I'm not disputing your results or experiences. But if you look across different cars, drivers, venues and weather, the results may not be the same in every case.
Old 09-18-2024, 07:15 PM   #13
DaveC113
DaveC113's Avatar
Gotcha,
RE sidewalls are so stiff it's nearly impossible to mount some commonly used pinched applications, even when only pinched a small amount. Slightly stretched is better anyways, but sometimes people are limited by rules.
Old 09-18-2024, 10:06 PM   #14
Christian1LE
Not in my experience. I also took both tires to Road America after Mid Ohio and the Nankang was still faster.(A052's had about 5 heat cycles on them at this point vs 10 nankang) It wasnt until the nankang was about 14 heat cycles in that the A052's started getting faster.
