![]() Drives: 2017 FIFTY 2SS HCI Join Date: Feb 2022
So I finished up my heads cam and took the car for the first ride and under a minute it starting blowing oil smoke. I shut it off and pushed it home. Upon pulling the intake manifold I realized it was drenched in oil and my catch can was instantly full so it was spewing oil out the pcv. Upon pulling the head I realized I put the damn head gasket on backwards like a dumbass.. Do any of you think this could have caused any issues? I talked to cam motion and they said no I didn't drive it long enough and that it was blowing combustion gasses past the gasket and into the crankcase and pressurized it, in turn causing it to spew oil out the pcv but it was hard to see any leaks on gasket because it ran for such a short period and its a cometic gasket. Any suggestions on anything I should check???? Do any of you think it could have done anything?
Last edited by Colin101234; 09-18-2024 at 03:57 AM. Reason: Wanted to add the help icon |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
That's why they print this side up on them, that was an epic fu though. Unless you got a crankcase full of coolant or oil in the cooling system I would just clean it up, change the oil and run it on the current plugs until clear and then change them.
I think you will be OK.
Other than being more attentive to gasket and other parts orientation, I would suggest maybe revving it a bit in the driveway before taking it out for a road test. A long time ago I installed a new Holley carburetor on a '73 Challenger. While my brother was revving it I smelled gas in the exhaust. The power valve had been cross-threaded and fuel was getting around it. |
SO turns out the oil had nothing to do with the head gasket being on backwards. It was because I ground off the solenoids under the valley plate and that was what was causing my low oil pressure and it was spewing the oil up into my pcv. (This is because those solenoids keep the pressure from the tube that runs off the pressure sensor, I did not know this) It was litterally shooting oil around my valley at 30 psi and easily allowing oil to get sucked up through the pcv. Everything happens for a reason tho because that was my saving grace. It made me pull the head where I realized one of the gaskets was backwards. The head gasket did not blow and it was not pressurizing the crank case nor was coolant going into my oil. So it actually worked out and only cost me a few hundred bucks!!!!
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639]) 1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune. |
![]() Drives: 2023 Camaro 2SS Join Date: Aug 2023
I guess this was another sacrifice to the Gods of Speed.
| Tags |
| advice, build, cam, headgasket, heads |
