![]() Drives: 2018 2SS 1LE Join Date: Feb 2018
Corsa NPP Valve Not Fully Closing?
In stealth/closed mode one muffler is still quite loud and sounds like the valve is not fully closed. I can't figure out why /what the issue is. Have chopped the valve connector butterfly things years back but now the rattle has returned when valves are closed and it is much louder than it should be in "closed" mode. Has anyone found a way to address/fix?
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
can see the flapper in the tail pipe and see if it's fully closed, or not?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
Maybe contact Corsa support to see what they can do for you. KingLT1 has the Corsa NPP and they have replaced his.
https://www.camaro6.com/forums/showthread.php?t=608352 |
#4 | |
To answer other question it’s hard to see valves with corsa since there’s a curve in pipe unlike factory npp
2018 1LE
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
same thing happen with my afe one also before the flapper valves get stuck sometimes or maybe it just needs to replaced
The Corsa while sounds amazing, definitely has a problem with their valve design. I am on my 3rd set of mufflers and have another valve rattling.
Corsa sent me a service kit that places a spring loaded washer on the button head end of the valve shaft. The problem is my valves are still the gen 1 that is all 1 piece. The last set of mufflers I received were supposed to be gen 2 which are serviceable. So currently I am going back and forth with Corsa. Now they want to know if the car is modified...blah blah. Told them it's no different than a ZL1. Waiting to hear back.
#7 | |
